s13pignose »
https://forums.nicoclub.com/s13pignose-u35261.html
Sat Feb 04, 2006 2:03 pm
Yeah just like the title says. They're def not name brand, but got em for a good price all as a set new. So as long as they don't break or rust I'll be more than happy. I don't even focus on drifting, autocross, or anything like that since my car is an automatic. So I hope the don't break.
Anyway my question is how do you adjust them? I was freakin out for a sec. Mainly cause all the nuts on one RUCA were all stacked back to back, but the second arm had two nuts back 2 back then a small gap b/w them and the last nut. SO I was like sh*t. There's basically one small nut and two big ones, and the smaller is on the actual joint and I knew that was adjustable. I tried turin the bigger ones and they seemed stuck, so I figure they didn't adjust. Later I twisted a lil harder and got em all to move, so they're the same length now. 3 nuts in all.
So are all 3 suppose to move or should any be welded in place? Also how do you go about tightening the nuts, and which ones do you do what with. I tust need to know so I can tell who ever installs them, because my instructions are all in japanese. Also if you got the time, can you explain adjusting and tightening toe arms too? If not, if anyone can provide me with links for installing the two I would REALLY appreciate it.
This is for a 95 s14 btw.
Thanks!!
