just got my first 86 Z N/A need Help
A home for 1983–1989 300ZX owners!
1 Bad Datsun
Car: 1986 Nissan Datsun 2+2
I bought a 1986 Nissan 3.0 N/e about 175,000 on it. I got new timing belt, water pump, radiator, struts, shocks, exc.... My mechanic told me my computer was on test mode and he took it off of it the best he could he said it will never b the same since it was on test mode so long,and the computer was changed at sopme point. Also he told me to look over the injection system. My car has a rough idle when warming,and when I'm stopping at a stop sign it seems that the car shuts down for a blink of a second resetting my radio and shutting off my lights and the motor slightly goes off and back on again all in a split second. Is it my ecu? Or injectors? Or what.I had a 92 probe valcan 3.0 and it did the same thing and i changed the ignition coil and ecu and ran perfect. Please help me out guys.oh ya what are the symptoms of the maf sensor
Thanx alot, Kevin
Black95s14
Car: 1995 Nissan 240sx
Should be in the classic z section...this section is for z32's (1990-1996 (1989-1998 in japan) 300zx)You have a z31 (1984-1989 300zx)
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
um, I think your mechanic is full of it, I have never heard of leaving an ecu in test mode being any problem at all, and I I recall on the z31 it automatically leaves test mode when you turn the key off
evildky
06 Nissan 350Z GT
and on the rough idel when warming up, check the CHTS (cylinder head temp sensor) it's in the base fo the drivers side head on the front of the engine, also might want to check the FICV (fast idle control valve)
1 Bad Datsun
ok i will look at that temp sensor i heard of that mabey being the problem to.
thanx,
1 Bad Datsun
alright what if its a different computer. Cause i know that the Probe i had had a bad computer and it would shut down like this car does, but the probe would almost die out this car only does it for a blink of a second, but u can notice cause radio and everything goes off and resets lights go off for a second and motor shuts down but only for that second and its really making me frustrated now.
Just give me some ideas what I could be looking at.
evildky
06 Nissan 350Z GT
kinda sounds like a common grouns issue? or perhaps one of the main power feed relays? maybe even the ignition switch?
NissanSportMag(Z31)
Car: A few Z31s.
Look for a bad connection. Either around the battery, alternator, fusible links, etc. The ECU doesn't have any control over anything but the engine. So if your radio resets and your dash dies, it is not ECU related.
Modified by NissanSportMag(Z31) at 12:55 PM 6/28/2006
1 Bad Datsun
we'll the motor shuts down,lights,dim,radio restarts.itz all right as soon as the exhaust "pops" going to lower speeds (like stopin at a stop sign).i know itz almost ecu related cause itz been changed once and itz not the right one in there i was told.but do n/e of u guys got an ecu liein around for my 86.
i atleast gada try i'm stuck right now and ill try n/e thing.
More info more info!!!
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
1 Bad Datsun wrote:we'll the motor shuts down,lights,dim,radio restarts.itz all right as soon as the exhaust "pops" going to lower speeds (like stopin at a stop sign).i know itz almost ecu related cause itz been changed once and itz not the right one in there i was told.
No. It isn't the ECU. The radio and lights have absolutely NOTHING to do with the ECU. So them being affected means it HAS to come from somewhere else. An incorrect ECU will make the car run poorly at all times, not just decide to cut out once in a while.
1 Bad Datsun wrote:but do n/e of u guys got an ecu liein around for my 86.
Try the classifieds, e-bay, or other Z site classifieds.
1 Bad Datsun wrote:i atleast gada try i'm stuck right now and ill try n/e thing.
Was that English? God I hate people who are too lazy to attempt to spell out 1st grade words like "ANY". This is a message board, not a text message to your homies.
1 Bad Datsun wrote:More info more info!!!
Done.
evildky
06 Nissan 350Z GT
lol, AZ is right, the ecu has nothing to do with any of the other systems, if the car runs fine, then the ecu should be ok, I'd start looking for ground issues
1 Bad Datsun
AZ-ZBum wrote:No. It isn't the ECU. The radio and lights have absolutely NOTHING to do with the ECU. So them being affected means it HAS to come from somewhere else. An incorrect ECU will make the car run poorly at all times, not just decide to cut out once in a while.Try the classifieds, e-bay, or other Z site classifieds.Was that English? God I hate people who are too lazy to attempt to spell out 1st grade words like "ANY". This is a message board, not a text message to your homies.Done.
U shouldn't b worryin bout how i wana type.i'm here 2 learn about this car not get taught grammar.
1 Bad Datsun
evildky wrote:lol, AZ is right, the ecu has nothing to do with any of the other systems, if the car runs fine, then the ecu should be ok, I'd start looking for ground issues
Now if you read what i'm writing you would of read the engine has a problem.Its now just the dash and radio those were my signs to hear that the motor shuts down for a split second."its the ECU" ya u guys sure helpd alot....
AZ-ZBum
1 Bad Datsun wrote:U shouldn't b worryin bout how i wana type.i'm here 2 learn about this car not get taught grammar.
Well it's pretty obvious you dropped out of school before learning it there. So we'll help you on this message board with that as well.
And the truth is, YOU should be worried about how you want to type. No one will take you seriously if you can't form complete sentences and use even the most basic of grammar.
If you expect any more intelligent answers, you'd actually try not to sound ignorant. Most people aren't receptive to people who don't even attempt to sound professional. If people have to go out of their way to try to understand you, they generally ignore you.
winez31
Car: 1993 s13 ka24de
and hey did u ever think alot of spelling and grammar errors are because of the fact were not all amazning typers? just cuz we suck at typing doesnt mean were dumb. dumb is ignorance which is you az bum
evildky
06 Nissan 350Z GT
easy does it peoples, and punctuation and gramar are definitely weakpoints for me as well, mathc and science were much easier in school
AZ-ZBum
Yeah. For me too. But we aren't talking a thesis paper. We're talking basic education. You know. Something a 16 year old should be able to grasp by now.
I didn't realize spelling the words "YOU", "ARE", "FOR", "TWO", "BECAUSE", etc were such and advanced level.
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
damn right. i can live with no capitals and/or no apostophies but cutting words down to save you time but still take the same amount of time as just writing the damn word like "n/e" is f^@king DUMB!!!!!!!!!! Just press a, then n, followed by y. had hard is that. it takes the same time to write as n/e but yet people can understand "any" quiker than "n/e". Looks like your the minority here so don't reply to this bisnitch.
PS not you az
1 Bad Datsun
how about this "Wa" FU*- Uyou like that you h0m0.
sorry for the disrespect to you other guys but this guy is a DIC*
wa-chiss
2005 Toyota Sequoia
you know what. I AM a d!ck, I HAVE a d!ck, and I USE my d!ck thank you very much. At least i can write so everyone can understand me. Like AZ said. People don't really take you seriously if you don't take the time to write propperly. Take it from someone who knows from experience. I used to write exactly like you do. the reason i dont anymore is because people kept bitching to me telling me they couldn't understand. Think about it. Your asking people for advice about a car. If you write the way you do, people are going to think you are 1) 12years old, 2) dont even have the car your talking about, and/or 3) someone with no form of prior schooling. So please do us all a favor and spell it out. It's easy once you get the hang of it. You never know, you might even enjoy it.
PS: I didn't mean to sound like a d!ck. I had a few beers to go with my fireworks. So, I'm Sorry
wa-chiss
2005 Toyota Sequoia
Also, It's way too easy to act all macho on the internat......
You can't see the person you talking too.
I bet if we met you could probably kick my ***.
and I ain't no h0m0................
1 Bad Datsun
Alright,Your a Fuc*in Lame *** Little Bitc*.I Also think your a Dic*head for writingthat nice little paragraph. You took that much timeout to tell me that?Damn u must of found out the hard way....
oh ya,and if we did probobly meet I would Kick Your ***so if you got the time to cruise Archer av.in Chicago at around 1-1:30please stop at the garage across from Burger King.
Peace
evildky
06 Nissan 350Z GT
go to your corners......
locked
Return to “300ZX (Z31) Forum”
