Theres always one here you go:Hijacker wrote:220 whp on 5 lbs of boost? No way. Not on a stock turbo.
He wasn't doubting your numbers, just your numbers on the stock turbo. Stop freaking out about it. There's more to your engine. You either have an aftermarket turbo or a set of cams. I'd guess you have an aftermarket turbo. His and my point is, you aren't making those numbers on a stock engine so find out what is modified. As regards the 5.8 PSI problem, the wastegate spring is stuck.Jadesr20det wrote:
sorry if i came off as spazzing out. I just get the same hard time whenever I state my #'s. But its all love to me. I understand what you are saying w/the aftermarket turbo however i have a stock turbo (t25) checked the turbo when it came in. Not sure about cams but they didnt look aftermarket and car doesnt idle any different (actually kinda tame compared to some stock SR'S i've been around) when i changed the valve cover gasket. I do however have full 3inch catback, front mount, walboro fp,and thats about it. I just dont understand how some can say that those #'s are not possible with the t25.redtop91 wrote:
Modified by redtop91 at 1:47 PM 11/25/2007
well then you didnt read what i wrote if thats the case as i posted the dyno chart which means the dyno (thats hooked up to the car mind you, which is why it is able to come up with exact #'s) is wrong. Hmm i think i will go with the dyno that is one of the best in this area for being accurate and actually stingy at times, than doubters (that weren't there) over the internet. Like they say the #'s dont lie, and if anyone else doesnt believe call them up their # is on the sheet or make a trip here and pay for my dyno time and we can do it all over again. Maybe i have a magic motor from DK himself lol but the fact is the motor made the #'s.redtop91 wrote:You didn't read what I said. No one is doubting that the T25 can't do that, it just can't do those numbers on less than stock boost. That is where the problem is. I believe your gauge is misreading.
correct something is wrong its called having the boost set too high and car leaning out way too much(look at the a/f ratio). Did it again but again boost was too high so he didnt finish the run (which explains the 0 lbs of boost that and the fact that we didnt unplugged the dyno from the source itself to see what numbers were achieved). Then we unplugged the BC all together and went back to stock setup and acheived the number you SEE before you. #'s dont lie and your lying to yourself if you think that way. Im sure if it were your car you'd feel the same way I do.Eikon wrote:You say the number don't lie.. but I tend to dissagree.
There is something wrong with your dyno charts. I think the boost readings are incorrect.
According to the chart you made 163whp on 16 lbs. then 165 whp on 0 lbs. then 219 whp on 5 lbs...
Something isn't right with that.
LOL. If it were my car I'd ask for the money I payed for the dyno back.Jadesr20det wrote:Im sure if it were your car you'd feel the same way I do.
umm your point? You started off with 1300?idahotuner wrote:lol carbully has 69 post lol
How can you say that for sure? It's not commonly done because it's not listed in the swap guides. I extended my wires to use the solenoid and voila.redtop91 wrote:It's not the solenoid people. Stop saying that. It's the restrictor in one of the lines.
Finally... thanks man lol.CMG wrote:How can you say that for sure? It's not commonly done because it's not listed in the swap guides. I extended my wires to use the solenoid and voila.
You should do some research on how solenoids function and answer that question yourself.CMG wrote:How can you say that for sure? It's not commonly done because it's not listed in the swap guides. I extended my wires to use the solenoid and voila.
Have you ever personally had an SR swap with the solenoid hooked up? Me and bgsr240 could be wrong, but we are two people who have first hand experience, which I would rely on far more than any web topic you could point out.redtop91 wrote:
http://www.nissansilvia.com/fo....html
Even though you are wrong that is a discussion for another topic. Not this one.
Ryon used an Apex'i AVCR to control boost. I however did use the boost solenoid in my swap, although now I'm running Ryon's old AVCR (Thanks!).CMG wrote:Have you ever personally had an SR swap with the solenoid hooked up? Me and bgsr240 could be wrong, but we are two people who have first hand experience, which I would rely on far more than any web topic you could point out.
