just got my first 1989 240sx!!! what is the stock motor for this car?
ben240
Car: 1989 240sx
i feel dumb but im new to this. any info helps. i just want to start to rebuild the engine that i have. thanks
240marcuSX
Car: E34 525i
E46 M3
You sir are the proud new owner of a KA24E.
Be a pal and use the search button to the right.
glad to have you here, youre like Ben #5,937 on nico.
ben240
Car: 1989 240sx
i love having such an uncommin name! i just looked and its a single cam. the KA24E is a single cam motor. any idea what i shoult tackle first? engine wise?
240marcuSX
Car: E34 525i
E46 M3
read up on the timing chain issue, as that could be the most severe.
Its always a good idea to change the air filter, fuel filter, spark plugs, plug wires, change the oil and oil filter, transmission fluid, Diff fluid (even though you dont have an lsd), flush the coolant, brake fluid. pretty much any fluid you can think of.
are there any wierd issues with it? any noises? tell us more about it.
ben240
Car: 1989 240sx
it sound and drives great but i know the other owner didnt have anything else on there mind but oil changes. the whole radiator setup was just replaced. its an automatic. it looks to leeking oil or the head is just really dirty not sure. is there a good rebuild kit for it?
240marcuSX
Car: E34 525i
E46 M3
I cant think of any rebuild "kit"
when you say kit, what parts are you thinking the kit would include?
ok then the coolant should be fine. change the oil, and check it often to see if the level goes down, clean the dirty area and see if oil gets on it again quickly.
It wouldnt surprise me if it was just really dirty, the car is 17 years old.
ben240
Car: 1989 240sx
will do. when i say "kit" i mean i saw a kit that had gaskets, pisstons, stuff like that? i dont know... could you recomend a web site i could order parts from?
240marcuSX
Car: E34 525i
E46 M3
courtesyparts, nissanparts. check out the nico sponsors. (the links on the right of the page)
it shouldnt be too hard to find a complete gasket set, but you probably wont need to tear into the motor and replace the pistons or anything.
do a compression test.
If you really want to, you could find another motor, rebuild it with all new oem parts, (or buy a new motor $$$$$$$$$$$) and put it in and it would be just like new. either way that would cost you a good bit.
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
go do a compression check on it and if its fine then....your motor is probly fine. "if it aint broke dont fix it." KA24's can run for a very long time without breaking down.
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
But, when they break down, they take everything with it, including the wallet. Then all that is left is a dull pain in the bum
