just got my 88 300zx
A home for 1983–1989 300ZX owners!
dogdog130
Car: 88 300zx
yea i got the car for 1000$ great car only 60,000 miles on it and i want to turbo the car how hard would it be , what would be best to do
Roach
Car: 89 Z31
read
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the best thing to do is to sell the n/a and buy a turbo, decent turbo cars can be had for only a few grand these days
if you must swap your chassis it's much easier if you can locate a complete donor car, you'll need:front crossmemberoilpanturboturbo manifolddownpipeoil linescoolant lines if you get one with a watercoled center sectionmafair ductinginjectorsecu
it's easier to just get a turbo car, but I did swap mine, see the link in my sig, of course I started with a $200 car
ZSpecs
Car: 1992 Z32 2+2
evildky wrote:...it's easier to just get a turbo car, if you can find one with a good body, that runs well, if you can afford it, and don't mind paying a little more in insurance, but I did swap mine, see the link in my sig, of course I started with a $200 car
I fixed it for you.
evildky
06 Nissan 350Z GT
lol, unless oyuare 16 the insureance isn't much different, a 20 somethgin year old sprots car taht can be outperformed by a modern minivan isnt't the biggest rick on the road
and a lto fo them do suffer form rust btu for a few grand you can get one that doesn't, maybe you need to look further south of CT, he's in NC so I'm gonna guess rust isn't as much fo a problem
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
ZSpecs wrote:
I fixed it for you.
The difference in insurance between my 1984 NA and my 1984 turbo was $25 every 6 months. And that was on the comprehensive. So most likely because of the t-tops. The liability part of the insurance was exactly the same.
Perrenial Badass
Car: 1973 240Z, 1986 300ZX, 1987 300ZX, 1984 Corvette
I was paying about $120 a month for my 87NA whereas a guy one year older than me was paying $98 a month for his 85T. That was at 16, price didn't go down when I turned 19. I don't currently have the f***er insured.
evildky
06 Nissan 350Z GT
I pay my premius in full but for $650 every 6 monthc I have full coverageon my 04 Z71, liabulity on my 91TT and liabulity on my 87 n/a-t
SATAN
Car: 1985 3Nissan 00ZX heavily modded
1984 Nissan 300ZX Anniversary stock
1990 Infiniti Q45 stock
I personally think it is better to turbo the NA. You will make more power on stock boost settings due to the higher compression in the NA engine.
Oh, you also don't need the turbo MAF. The NA MAF will work fine.
evildky
06 Nissan 350Z GT
doah! so the maf's are the same, I'm nto running one so I wouldn't know:)
turbo n/a's actually feel slower imho, I had a turbo'd turbo motor before popping ti and swappign int he n/a block, I guess the increased bottom sort of decreases the angle of the hp curve, and yes the n/a will make a small amount of additional power due to compression ratio but it's not really noticible
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
Before you worry about a Turbo you probably need to get the timing belt, water pump all refreshed. If the previous owner hasn't done this your way overdue...even if they did it and the car is not due to get this done by mileag (every 60k) you should do it at least every 10 years or so. I had only 20k on my Z's timing belt after doing it around 147k but 10 years later everything was in bad shape. New timing belt, water pump, cam seals, new hoses and belts were required to get things back to goodness.
You should be more worried about that than putting a turbo charger on the car.
SATAN
evildky wrote:doah! so the maf's are the same, I'm nto running one so I wouldn't know:)
There was speculation long ago that the mafs were different between turbo and non turbo z31's. I believe it was when Nistune came out that people discovered that it did not matter which one you had.
Personal experience... I put my turbo maf on my friends NA just to get him by for a few days. He did not notice ANY difference in the behavior of the car.
evildky
06 Nissan 350Z GT
lol, well thats one way to find out, nissan seems to like to assign different part numbers to the same part adding to the confusion, the Z32 n/a and TT have different part #'s and prices for COP's btu they are functionally the same
Return to “300ZX (Z31) Forum”
