Just got my 240sx..help!!!!
youngs13lover
Car: 1992 240sx
hay everyone..i just got my first car..its a 1992 240sx..ive done alot of research on them the engine everything..the motor i have was out of timng was put on perfectly and i found out i have a bad piston... i dont wanna have to rebuild everything because if i do im gonna want to go all out..instead my homeboi who is an amatuer drifter and mechanic is a close friend he is gonna get me a stock motor and tweak it up for me and put alittle power but not much cause he says im only 16 and i cant handle all the power..i wanted to buy his high compression ka24de with sohc internals but he thinks its 2 much for me...anyways..wat im trying to get at is should i keep my motor and let my car sit and rebuild it or should i get this motor from him and start working on this i can handle in my budget like coilovers headers exhaust fuel management......hes selling me the motor for $350 and im gonna give him my ef'd up motor as a trade for installing the motor and wiring it instead of paying him cash
youngs13lover
Car: 1992 240sx
lol thanks for helping..anyone else
AZ89two4Tsx
youngs13lover wrote: high compression ka24de with sohc internals
Oxymoron?
Dave_Dynamite
Car: '90 hatchback
GODDAMMIT AZ YOU HAZ SEXY CAR!!!
King Ranzo
Car: 15 Ford Focus ST
AZ89two4Tsx wrote:
Oxymoron?
It has actually been done and it actually works really well. Also, wtf is up with you and colors. What are you gay? Oh...I spoke too soon.
youngs13lover
Car: 1992 240sx
he said the high compression motor is to much for me..and u have to run 93 octane on it....lots of maintenance...should i get a motor or build my own
s13 iDRIFT
Car: White s13 Hatch
if the motor he has if it runs fine why not, unless you just wanna be uber cool and build your own motor!
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
SOHC pistons in a DOHC motor do increase compression..... But minimally
First, go back and edit your bois and wats to English, its painful. Second, if your engine has bad piston damage then get a new engine, you can pick up a KA24de here on Nico or local for 100-300 bucks. Check compression before you buy, and freshen it up with a gasket set.
Ohio_S13
Car: 1990 R32 GT-R, 1999 Ford F150, 2002 Infiniti G20, 2013 Honda Pilot
youngs13lover wrote:he said the high compression motor is to much for me..and u have to run 93 octane on it....lots of maintenance...should i get a motor or build my own
If it lots of maintenance I would not do it....just find a regular KA engine in good shap and build the rest of the car.
hilux30
Car: 2007 Tacoma 4x4
ahhh... I remember when I was sixteen, thought I knew everything but in trueth did not know jack, did more damage than good 240's are great first car to learn things, I had to do it on a regal T-type turbo 84 and an 80 caprice 2-door big-block, it was not fun most of the time. Ka24de are cheap, simple and strong motors, very torquey. But running SOHC internals that I must disagree, SOHC rods and pistons are even weaker. Don't freak out when things go wrong, just analyze, weigh options and do study things carefully. things will go wrong, if your not up for it then lease a new sentra or something, otherwise good luck and keep the racing off the streets
youngs13lover
Car: 1992 240sx
i will definately keep it off the streets...orlando motor speedway isnt to far and niether is cfrc... the motor is coming with
new head gasketrod bearingsshaved headclevite 77 bearings2 exhaust camsretard timing by 3 teethsohc pistons...only $400 for the motor and im giving him my motor and ac for him to install and wire it..i dont use ac because my contacts dry up and is not safe...
Edit..i guess people with high compression use e85 fuel..i just found i live 10 seconds from a pump with e 85 and didnt even no it..$2.24//anything else i need
Modified by youngs13lover at 12:51 AM 8/15/2009
noobdrftr
Car: of crap...just pure crap
a tune for e85
youngs13lover
Car: 1992 240sx
wat??
24j0hn
Car: 91' 240sx with some babying to be given
i honestly dont think that youll need to run higher octane gas because there is sohc parts in the ka...
the engine may have high compression but it doesnt have a high compression ratio, and by the sound of the build that your friend did on the motor its just a motor w/ new bearings and a new head gasket w/ a resurfaced head...
but i say buy it cuz its only $350 but you probably wont feel any difference with the new motor and a non rebuilt one
sylintstorm
Car: 91 240sx hatchback
Too bad you don't live in PA. I have a running de out of a 91 hatch sitting in my garage.
youngs13lover
Car: 1992 240sx
24j0hn wrote:i honestly dont think that youll need to run higher octane gas because there is sohc parts in the ka...
compression ratio is about 12:4:1
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
It should be more around 11:1
Modified by mattblancarte at 2:26 AM 8/16/2009
youngs13lover
Car: 1992 240sx
well even if it is..is running e85 ok..or 93 octane
SupahTyTeTwoFowty_y0
Car: at least 15 but no more than 2
my lawn mower is running on 93 octane. no joke.
