just got mine GT2871R!!!!!
Dugi
Car: dragging
Just got mine GT2871R!!!!!! really happy. A/R .86 cause it'll be used for street & strip. Polished and everything the thing just looks great. bolts on really easy. oil lines hook up, only the waterline needs to be fabbed up. a few holes need to be bored out on the dump pimp. Turbo needs to be reclocked, outlet and intake need to be fabbed up also. So it's all small things that need to be done for the rest it's alll good. i'm running the tial wastegate on the stock mani at the moment. I'm also converting to top feed injectors, 720CC. Management will be done with a microtech LT-8. Anyone else running the GT2871R?? can't wait to test the thing. will let you know how it went.
mynismo
i have an s13 with the .64 trim
getting the car back today or tomorrow (had a minor prob ), should be running then.
who does your tuning? i sent my ecu to enthalpy.
Dugi
Car: dragging
Well I'm not fromthe US. I'm located in the carribean. Tuning is done at a local shop by J&S racing. they have the fastest 4 cyl on the island. we don't have dyno's on the island so all tuning is done on the street with wideband O2.
DawgMode
Car: 180sx
What part of the carribean are u from???
Dugi
Car: dragging
Curacao...... small small island....... just up north of venezuela.
civicsi2
I've got one but I'm kinda wishing i had the .64. You'll see. Its all fun.
I'm running the aem ems and nismo 740cc injectors.
pgt892
Car: 1997 240SX
This is the turbo I am thinking about getting. Do the Taka T25 lines fit on this?
Dugi
Car: dragging
Well the original T25 oil lines fit on the GT2871R, only the waterline needs to be adjusted.
Hey civicsi2 what boost are you running?? and at what duty cycle are your injectors???
mynismo
i got mine running last nite.
sick!!! the .64 trim is nuts, i love how the boost comes on so early, its only a tad later than the t25, but when it hits it hits hard.
im running too rich, scotts sending me another tune but other than that the car is great. dynod 300whp at 15psi with a 10:1 a/f. once i fix that a/f i hope to hit 350.
its a great turbo!
pgt892
Car: 1997 240SX
Dugi wrote:Well the original T25 oil lines fit on the GT2871R, only the waterline needs to be adjusted.
When you say needs to be adjusted, would that be possible with the flexible water line available with the Taka kit? Or would the line just not fit at all? Thanks for the info.
Dugi
Car: dragging
mynismo what injectors are you using?? I'm also running way too rich. What duty cycle your injectors got?? Can't wait too feel the power....
pgt892 what we did... we just cut the lines and used a hose and clamped them to the fittings of the waterline... no hassle..Cause the oem waterline will come up short....... i'm not sure of the taka kit cause i'm not familiar with it but if it has a flexible hose then i would think it'll fit
mynismo
i got the 650cc's off ebay, but they appear to be flowing much more than that. scott is making a new tune for me.
not sure what duty cycle they are.
new tune is coming friday, if i dont post here check out freshalloy adv.
nissanrcer240
Car: 90 Nissan 240SX SR20DET
[QUOTE=Dugi]Just got mine GT2871R!!!!!! really happy. A/R .86 cause it'll be used for street & strip. Polished and everything the thing just looks great. bolts on really easy. oil lines hook up, only the waterline needs to be fabbed up. a few holes need to be bored out on the dump pimp. Turbo needs to be reclocked, outlet and intake need to be fabbed up also.QUOTE]
Sorry for sounding ignorant, but what do you mean when you say the turbo needs to be reclocked? I know the outlet and intake pipe need to be custom, I have that planned out already.Im ordering the gt2871r a/r .86 soon and I plan on installing it myself so Im trying to figure out everything I need to do as far as a proper "new" turbo install goes. I appreciate any help
mynismo
clocking the turbo is simply a matter of loosening all the bolts on both sides of the middle of the turbo to loosen the middle section. then you rotate it to match up with your lines and our motor (about 180 degrees).
the actuator will need a little playing around with but it fits right up, you'll know what to do when you are at that point.
Dugi
Car: dragging
yep what he said ^^^^^^^^^^^
mynismo
my car is finally tuned!
she pulls
will have dyno monday or tuesday if it doesn't snow here.
Dugi
Car: dragging
my car also but still a bit rich.. road tuning is a b****. had some trouble with the wideband O2 but the car runs good..... sunday I will be testing my 1/4 mile...... stay tuned
mynismo
gt2871r dyno comparison threads are up at freshalloy
http://forums.freshalloy.com/u...b=5&o=
pgt892
Car: 1997 240SX
That comparison graph was great info. While the .64 predictably boosted earlier, the .86 had a really nice, steady rise of power. Makes me want to get the .86.
mynismo
actually, the .86's rise in power is almost exactly the same as the .64, the .64 just peaks a hell of a lot sooner.
i've driven in both, and lag is very noticeable in the .86, but is almost nonexistent in the .64.
if you want topend power, get the .86.
if you want a fun car to drive, get the .64.
spanishricer
Car: '95 240SX & '03 M45
I'm thinking with a nice exhaust manny *cough* full-race *cough* the .64 would generate just as much top end power as the .86 with the stock log manifold. And without sacrificing too much spool up time. Any thoughts on this?
mynismo
if you're willing to spend a grand for 20whp, be my guest
spanishricer
mynismo wrote:if you're willing to spend a grand for 20whp, be my guest
Hehe, well I think you'd gain a bit more than 20whp running 20 psi on a GT2871r...but you never know Besides, a nice manifold is a great addition when you've "exhausted" all your other options...hahaha...haha...ha...hoooo boy, I crack myself up
