Just got me a valve cover
sohc90adel
Car: 1990 Nissan 240sx HB 5 speed Grey
Just got me a valve cover and am going to bead blast then polish to put into my baby. Question is does anybody have any suggestions about what to do to clean what i am going to see when i take that cover off? I figure if i can do something that will help the car when i take that cover off it will be worth it. Let me know.
Aries
Car: LT1 240SS
well, cleaning is easy.use carb and choke cleaner to take of the grime, and then use simple ggreen and a bruch to clean out the crevices and anything left over.
blast, and paint/polish :)
main thing to do is to keep track of the bolts, and not let them fall into the motor ;) otherwise unless you are replacing more parts there isn't much you can do but check tightness on bolts :)
ADAMHU
here is how mine turned out...
Sleeper s13
Car: road racing
nice:cool: My valve cover gasket replacement was a nightmare. the screws striped out the threads on the head. Broke the T junction to my Injen short ram which by the way can be picked up at your local ACE. And when i went to move the fuel rail by unbolting it the metal supports that conneted it twisted rather than the bolt turning. Its probably just because im a cluts. Good Luck
sohc90adel
damn i hope mine comes out half as nice as that one good job. And i definatly hope i dont get any of the problems
Syntax360
Car: 1986 Nissan 300ZX Turbo
Sleeper s13 wrote:nice:cool: My valve cover gasket replacement was a nightmare. the screws striped out the threads on the head.
I did the same thing! beware torque'n that thing back on too tight....kills those damn threads
Voodoo
ADAMHU wrote:here is how mine turned out...
Sweet...
Mine is powdercoated....this was taken during the install of my '95 KA into my '91 Hatchback
SSS
I have the same problem with stripped valve cover bolt threads, can you run a tap through them to fix the threads up, or can you helicoil the damaged thread?
ricebike
2002 Quest
2005 Altima
http://www.jcwhitney.com/produ...=jcw2
how about using these aluminum welding rods to fill in the stripped holes, then drilling/ tapping them to the original size bolt/thread pitch?
Voodoo
ricebike wrote:http://www.jcwhitney.com/produ...=jcw2
I wouldn't bother...
Use a Hielcoil and be done with it.....it will be stronger and probably last longer than your car!
