Just got KAT running timing ???
aaronscomp
Car: s13
Just got my kat running im only on 7 pounds with a walbro 255 and fmu. What should i do for timing iver heard just retard it 2 to 3 degrees is this correct.
WDRacing
Yup, 2-3 degree's will give you a nice safety net
WD
oaznbeasto
Car: 95 s14
or you can suck it up, save, and get those 370cc injectors and an ecu tune FTW
aaronscomp
Car: s13
WDRacing wrote:Yup, 2-3 degree's will give you a nice safety net
WD
Thanks just making sure it runs solid on a fmu and walbro 255
oz240red
Car: 95 T3/T4 KA-T
That's why I'm running. Just get a boost gauge and dyno it so you know your A/F ratios, just to be safe.
aaronscomp
Car: s13
ya ill probobly buy a aem widebad set up here shortly
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Hope your engine doesn't blow...
An fmu might be ok, but do the essentials to know your setup will be reliable.
Retard timing + dyno w/wbo2 or wbo2 logs.
GEO
Car: 95 240sx KA-T
FMU's in my mind suck. Get some 370cc's and a high pressure walbro and you will be fine with the SAFC2. Timming wise, retard to 20-21 degrees at WOT
