Just got in two more Q45 AC Compressors...
DrewQ45
Car: 1990 Infiniti Q45
For 90-93 G50. Both drained clean green fluid when pulled.
Each $80 shipped to you.
DrewQ45
Oops... mods, please move to parts forum. Sorry about that.
qship96
Car: 1996 Infiniti Q45
and if you need a 94-96 compressor,I have one 80 shipped also!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
DrewQ45 wrote:For 90-93 G50. Both drained clean green fluid when pulled.
Now you just have to evacuate them and seal them to prevent corrosion from the atmosphere.
DrewQ45
maxnix wrote:Now you just have to evacuate them and seal them to prevent corrosion from the atmosphere.
I can do what I've done with all my compressors. Drain out the fluid then block up the holes. Evacuate implies vacuuming which is done when installing it. Some junkyards have them sitting open on the shelf for years and they still work.
qship96
new compressor{oem} comes with oil installed and suction & discharge openings covered with rubber plugs held on by a metal backing plate with bolts,it is leaktite,yet not under vacuum.I transferred this assembly to my old compressor when I installed the new.
DrewQ45
qship96 wrote:new compressor{oem} comes with oil installed and suction & discharge openings covered with rubber plugs held on by a metal backing plate with bolts,it is leaktite,yet not under vacuum.I transferred this assembly to my old compressor when I installed the new.
So what made you get a new one?
qship96
original one still cooled,was quiet,but the car seemed to take too long to initially cool down after parked in hot sun-replaced compressor and dryer-every tech looked at me like I was crazy to replace a working compressor that tested to spec - maybe a new dryer only would have done the trick?oh well,its all good now!
jy2004
Car: 97 Q45
Do you still have the compressor for 94?
Let me know.
Thanks
DrewQ45
Sorry, no 94 compressors. The 94 compressor has a larger pulley on it. 90-93 would work, you'd just have to change the belt to the slightly smaller belts of the early G50 but who wants to go backwards?
...Drew....
