maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Fri Aug 01, 2008 2:30 pm
Jerry has let others bring in parts from Joe.
If the ball joints and lower links are not bad, then think of shocks and upperlinks and tension rod bushings. Also all tother bushings including anti-sway bars, links and steering rack bushings, rubber gaiters with bump stops, front and rear. Even in the People's Republic of Kalifornia with parts from Joe shouldn't cost you over $1,600 for everything.
Do what Qship96 said and take it to Jerry for a once over. Might be more your non-Infiniti guy has missed or is afraid to tell you. Have you exchanged your PS HICAS fluid? You must unless you know it is less than 2.5 years old and is the correct fluid.
