just got done with my auto to manual conversion, NEED HELP
dsastr_clan
Car: 240sx
Hello guys,
I just got done with my Auto to Manual conversion on my N/A z32, i was super excited to finally get rid of my auto transmission cuz it sucked! my car is on drivable conditions
it starts fine, i haven't figured how to do the reverse lights yet but i dont think that would be a problem, my issue is here.... my clutch slips bad when im on third to fight gear, first and second seem to hold pretty good. Do you guys have any idea what could be making it slip?? has anybody experienced the same issue and fixed it? Any thoughts are welcome.
I have a resurfaced flywheel and a brand new clutch kit, new clutch disc, throw out bearing, pilot bearing, pressure plate, new slave and master cylinder. The clutch has been bled pretty good the pedal is hard and stiff.
inlowm523_90tt
Car: 1990 Z32
Could be because you have the brand new clutch..needs to be broke in..is it stock or aftermarket? The pedal shouldnt be hard at all...i have a stage 3 by fidanza and its extremely smooth...i did the auto to manual conversion myself. As far as the problem goes....When cruising in third gear does the shifter seem to jump forward slightly when you throttle up, and jump back slightly when off the throttle?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
pedal adjustment, you might have the pedal too tight, thy threadingt he pedal clevis in a few turns, and make sure at rest there si po pressure ont he clevis
dsastr_clan
Car: 240sx
Guys, thanks for all your imputs i got fixed, the pedal clevis was super tight which made the throw up bearing get stuck on the pressure plate, so i had to pry bar it out and then adjust the clevis behind the pedal, now the cars drives like is supposed to!! Thank you very much
inlowm523_90tt, let me ask you somethingm you mentioned that you did your swap yourself would you have some info on how to wire the reverse lights?? LOL
brizanden
Car: thrased kouki ftw
hey your pm is disabled i still have the 350z wheels. email or text me [email protected] or 740-816-4354
