just got back fromt the "stealership"
thintzen
the dealership has informed me that the reason my slip and vdc off light in on is because my brake pads and rotors are running low? does this sound corrent. and antoher thing, they sai the rotors are $130 because they are thicker and should last longer, aren't these the same rotors on the 350z?
thanks
infinititech1
yes those lights can come on because of low brake fluid which in turn is caused by low pads/rotors
thintzen
are the pads and rotors the same as the 350z, so that i may get them cheaper form a source at nissan? and are they any thincker than normal rotors, to compensate for the short lifespan?
infinititech1
i'm not sure if the brakes are the same...but if u buy new ones from the dealer they are supposed to be better than the ones that came factory that ware out so quick
