Just got back from the dyno!
Booztd 3
Car: 1990 Nissan 300ZX TT
Guys
Just got back from a dyno session @ sound performance in chicago
I maxed out the injectors, and I think I've reached the limitations of the stock ignition system. I'm hoping thats why it hiccuped a little around 7400
Final Pull was at ~24-25 psi, it spiked a little and then fell off
Final numbers:
718rwhp
587rwtq
Here's a link to the dyno chart (you can zoom in on it)
http://www.booztd3.com/Pictures/Dyno_Ch ... _25psi.jpg
Rain is heading in, so I only took it out for a few pulls......the car def rips...
Here's the 718rwhp dyno vid....youtube really killed the sound quality
http://www.youtube.com/watch?v=5fwqPIc-yt4
Heres a short vid out in the country....took it to right around 140 from a 20 or so roll....
http://www.youtube.com/watch?v=6qCW1DWH840
Big thanks to my buddies Greg (for lending his big-a** diesel) Brian (for the trailer) and Rusty for being the pit-crew and providing moral support
Eikon
Car: 71 240z, 93 Supra TT
Nice numbers Andy!!!
You are going to Omaha for the Nissan Nationals right??? It would be awesome if you could make it!
Sil240
Car: Nissan S13 "The One Cam Wonder"
Nice bro! !! Awesome numbers
meet07
Car: 89 180sx rb25det
Now on to the track!! Hope you break into the 9's with a manual!! Us that are RB/Drag inspired(like myself) take notes from ya..Keep it up brotha!!
Booztd 3
I doubt 9's are going to be capable with 700rwhp.......Im thinking somewhere near 800rwhp is goal for a 9 second ride that weighs 3700lbs
RustspecS13
Car: '74 260z and '88 300zx turbo
Very impressive! It sounds amazing at full boost, I really like the recir'd wg so you can still hear the engine inhaling and its refined exhaust note.
Do you street drive it often?
~Alex
Booztd 3
RustspecS13 wrote:Very impressive! It sounds amazing at full boost, I really like the recir'd wg so you can still hear the engine inhaling and its refined exhaust note.
~Alex
Actually I drive it to work most days............esp if its not going to rain
RustspecS13
That's cool, its always nice to see a built car used often.
~Alex
meet07
Have you considered putting it into a lighter body like a 260z or do you just absolutly love the 300??
Booztd 3
300's are in my blood....I have 3 of them, and I dont really think abandoning this project just to save some weight and start all over again in another chassis would really be worth the hassle, or money....
240z4u
Car: '95 Nissan 240SX
Gat damn!
Very nice!! Congratulations man.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Wow, nice Andy!
WhatsADSM
Car: 1998 240sx
Looks/Sounds really good.
It moved out really well in that vid.. It also hooked up surprisingly well.
Keep us posted with the new drag times as you get them.
stevespeed
Car: RB-Swapped S13, FTW
Holy Amazing
Awesome job dude!
Booztd 3
WhatsADSM wrote:Looks/Sounds really good.
Gotta love those mickey thompson drag radials :)
I'm curious about your launch process, I've trashed like 5 output shafts so far, and I'm going to go back to the drawing board. Before I had just been letting it build as much boost as it wanted (which was probably around 25psi) and around 5500rpms was where the limiter was set at. I'd typically just dump the clutch.
Im thinking I need to dial the boost down, and maybe give it some more RPM's.
When I raced for a few years on my VG setup, I never had a 2step, so I just revved it to 7k and dumped the clutch and I never once broke a damn output shaft....
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
very nice, congrats!! Love that 300.
WhatsADSM
Car: 1998 240sx
Yea I typically launch off the 2-step with between 17 and 20 psi. Then with the AEM I ramp in full boost (~24psi) once I get into the meat of 2nd gear. I kind of got my launch technique from my DSM days. I essentially start to slip the clutch a little bit and the instant that I feel the car start to move, I then quickly dump it the rest of the way. Haven't snapped anything yet. That way there isn't such a shock on the entire driveline. It gives the driveline a chance to engage a bit before full on power. Also with the slicks there is more sidewall flex which actually helps cushion the suspension a bit and ensure I don't get any wheel hop. Not sure if you are getting any wheel hop but that will kill driveline components much faster than normal.
All-in-all though, I gotta admit your launches (Even on the radials) are more impressive than my slicks. In part because I have my suspension setup to road race, and because I just have less weight on the back my best 60' last time I went out was just a 1.6 anyways... which is a ways away from you. ;)
Booztd 3
I'm going to have to lessen the boost and try to pre-load a little bit to keep from breaking stuff it seems like. With the aem 2-step options, I should be able to dial the boost down. If I set all 3 options (ignition cut, fuel cut, and retard) all to the same rpm, I usually get 0 boost.....
To be honest......some low 1.6's to mid 1.5's would be worth not breaking anything this year, versus cutting 1.4's and having to worry about those damn output shafts.....
flatrate
Car: S14 kouki
I saw that you have a nitrous setup, you ever use it?
Is your cylinder head ported or have any other work done to it...
Great power, love the build
Booztd 3
flatrate wrote:I saw that you have a nitrous setup, you ever use it?
This threads about a year old but.....
I sold the nitrous, never used it....only when I was helping put together the TH400 kit (which was also sold)
The head is stock with the exception of some Type-A pon-cams
flatrate
Car: S14 kouki
Yeah a little old, but you posted some good info and results... im looking for something around the 600whp range... i have an RB25 stock head, built bottom end... pistons rods crank collar etc..
going to remove the RB25 head and install a ported Rb26 head and intake manifold setup, any reason you went with 260/252 cams instead of the 260/260?
Booztd 3
Unfortunately at the time of buying cams, they were all I could get my hands on. Tomei was on backorder and to my knowlegde the 260/252's were the last ones on the shelf (for some time)
meet07
so for the most part a completly stock rb26 with drop in cams can make 700+ whp? So can the same be done with a rb25 with drop in cams like the 260's and some gtr solid lifters?
Cjmartz2k
Car: Hunting for a '89 GTR now
RB26 lifter won't just drop in to an RB25 head if that's what you are thinking. I don't think you need solid lifters anyways though. Also, I think the stock intake/TB and maybe the pistons might keep you from making a reliable 700rwhp.
