just got back from iraq...
branch757
Hi guys i just got back and i stacked up some paper!!i have about 8grand to spend. i want to use it all on the engine. i can get the other crap later. i want the "GO" before the "SHOW."i need some advice from the experts. my goals are 400hp everyday with the ability to go up to 500hp(safely with out blowing the **** up). i just want a quick rundown on what parts for the ka can get me there. i saw the stroker kit but that got shot down...oh by the way i searched and i have a list of parts::
uprgaded rod bolts micro polished. crankshaftnew valve seals3 angle valve jobSupertech performance pistons 8:5:1Cometic performance head gasketARP main studs ARP head studs performance rod and main bearings38mm waste gateHKS SSQV bovphatka-t gt35phatka-t turbo manifoldintercoolerphatka-t fuel system w/upgraded injectors 72lbstage 3 clutchlight flywheelpauter rodsjwt ecu (aem ems if i have the money)upgraded valve springsupgraded cams
if you guys could just look over them and add/subtract to help me get to my goals
i plan to start ordering everything mid Aug. right now im just laying down a blue-print on the parts. thanks
chandler
Car: 91 civic hb & 96 S14
i would go with the ems for sure at those power goals, your forgetting clamps, hoses, and other such nickel and dime stuff. good to have you back man
eddiec
Car: 91 S13
i'd second the ems idea.
neoamd
Hey man,
Just have Ivan @ PHAT KA-T build the motor
Or just drive te car to him and just drop it off..
I'll be joining the military soon!
Josh
branch757
i might be able to source the parts cheaper. i think i just want a shop to install them
hannibal
Car: Red Line to Glenmont
Thank you!
and welcome home...
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
8 grand you say, lets makes a quick list of prices of parts
I took the liberty of adding some parts...
Pistons: 490 (Supertech)Rods: 690 (Pauter)Rod Bearings: 75Forged valves: 320Valve springs: 400Valve job + porting: 650-850Cams: 400-500Cometic Headgasket: 100APR studs: 290
Turbo Garrett GT35R BB: 1400Manifold: 750DP:350Intercooler: 200-500HKS BOV: 23038mm gate: 250Flywheel: 550Clutch: 350AEM EMS: 1800phatka-t fuel system: 750+200 upgrade
Around 10400 bucks without any engine work (besides porting) and without intercooler piping, oil lines, gaskets, clams, shipping, tax.
Advice: keep saving…lol
Florida240sx
Buy Ivan's or tophat engien and go from there.But fi you are goign to be over 400rwhp you need the AEM EMS. so already you are doen to 2k for your turbo setup but your engine is bulletproof with superior tuning capabilities.
I'll let the experts answer the build questions...
Welcome home, and thanks for serving!
Jookmasta
by far, i would just buy an engine already built from either top hat or phat ka-t. unless u really feel the need to the piece by piece route, it will just be easier on the wallet. Checkered member's list is somewhat accurate but im sure i could probably knock off a thousand off of his total if not more with some diligent hunting for those parts. 8K is really good budget and as said before, aem ems for ur power goals. At that fuel level and power level, u really need a standalone to make sure that everything is tuned to a T
NateDogg
JWT ECU 72lb program is good for 500hp. Call them and ask around or search on freshalloy.com forums for T66240. You kats ain't been around enough to know these things! Besides, I think 500hp in a 2wd 3000 lb car is way too much. I would invest more into other things, like tires
Checkered-Member
NateDogg wrote:JWT ECU 72lb program is good for 500hp. Call them and ask around or search on freshalloy.com forums for T66240. You kats ain't been around enough to know these things! Besides, I think 500hp in a 2wd 3000 lb car is way too much. I would invest more into other things, like tires
True that, Those that can produce 500+ hp on their KA only run 400 at the track
cdlong
Car: '95 240sx
i'm really sorry, but i have to say this.
if i see another airman get back from overseas and spend all the money he earned risking his life on his car and save none of it, i'm going to puke.
do yourself a favor and put some of it away, college, a house, kids, there are many things you'll really need it for in the future.
sorry about that, it really pisses me off. i see it way too often.
thank you for helping out, i should be over there in may.
toki
Checkered-Member wrote:8 grand you say, lets makes a quick list of prices of parts
Pistons: 490 (Supertech)Rods: 690 (Pauter)Rod Bearings: 75Forged valves: 320 - you're smoking some crack, SI valves are $12.50 a piece, i'll just do some but math and tell you that comes out to about $220Valve springs: 400Valve job + porting: 650-850 - maybe in "recockulous priceville, TN" - valve job is $150, mild P&P there is ALWAYS someone in EVERY city who will hook it up for $150 or less. Cams: 400-500Cometic Headgasket: 100APR studs: 290
Turbo Garrett GT35R BB: 1400Manifold: 750 DP:350 - once again, you might be living in that city in TN.... $75 at any exhaust shopIntercooler: 200-500 - eBay r0x0rs your boxers, biggest damn intercooler you'll ever need is $220 to your doorHKS BOV: 23038mm gate: 250Flywheel: 550 - who the hell said you NEED a light flywheel? If you are going for 500hp, then I would guess he's probably drag racing, and well, I'm sure you know a heavier flywheel is actually preferable for that application.Clutch: 350AEM EMS: 1800phatka-t fuel system: 750+200 upgrade - re-cockulous once again, mustang fuel rail and some big injectors, $500 tops.
I coudl go on and on and about the other stuff, the fact people have already made over 400whp on a $250 Log manifold, you don't NEED a $750 manifold, you don't NEED a ball bearing turbo, **** a $750 Precision061 (I think thats the .63 a/r T350 / Gt40 combo's number) will take you to 500 WHP EASY every day of the week -- and the fact you can buy major standalones like a haltech or microtech for $1200 or less vs a plug n play EMS. The more work you do yourself, the cheaper it becomes. 500whp with 8,000 is VERY attainable.
fabio420
Car: 1995 nissan 240sx se
People, let's not forget the transmission and rear axle. Gonna need to upgrade those, and that's also money.Thanks for the sacrifices and welcome home!!
WDRacing
The transmission and Rear End are more then up to 500WHP. Already been done.
TOKI is 100% correct, 500whp is nothing but a turbo and boost away with everything in stock trim except the pistons and rods.
Combine a good turbo with fuel and timing control and I'll give you 500WHP in one day of tuning. It's really not that difficult.
Look at Ivan's project...Boost + Engine Management = over 500 to the wheels.
So 8 Grand is plenty.
