Just got an RB20det...need help...
Andy's RB'S13
Car: 1992 Nissan 240sx
i jus got a rb20det front clip from Venus and was wondering what i should replace i already have a greddy timing belt and all gaskets i was also told i can leave the stock s13 drive shaft because it works too what else should i replace before droping the engine in thnx plz let me know...
rotorimp
Car: 02 Xterra, 60 IH Metro
I would replace the Water pump--Those motors set for a long time before it got to you. Look at the clutch to make sure that you still have one left.
Sil240
Car: Nissan S13 "The One Cam Wonder"
You got it from Venus/?Better check that compression
Andy's RB'S13
compression is still great and the clutch is great too jus want to know what else i should replace on it before installin it in....
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Timing belt tensior and idler pully, water pump, a better clutch that stock unless your going to keep the car stock and put around town with it.
