Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.html
Mon Mar 29, 2004 7:43 am
No... there is no "frame" in a unibody car. The only way to measure for a bent chassis would be to compair overall differences in toe, caster, camber, and chassis centerline deflection.
As the vehicle wears your bushings will as well... remember how that cam bolt just moves the arm a slight amount to change the alignment? Well when the bushings and the rest of the suspension begins to sag you get various alignment angles.
You should have +/- 0.75 of camber change in the rear with the cam bolt, but remember you will not start at 0 deg. of camber. For performance, depending on spring rates, height, etc. an amount of rear camber between 1 - 2 deg. of negative camber is ideal. Toe should be zeroed out if not toed out a little to increase the steering response.
You have the same three measurements in the front as you do in the rear... however rear caster angles don't do anything because they aren't turning.
