Just got a new s14
zenkistic
Car: 96 240 SE
ok sir, you are correct. but I would never put the clear lenses that you meant in my zenki. it's like a very hot girl with see-through underwear. not that fun. I meant clean OEM lenses.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
I agree.. BUT if you retrofit some projectors into the housing then they would look good
mmaxeyjr
Car: 1995 s14
xC4RNAG3x wrote:lol man u suck bro...you know that was a steal for 3k lol. Yeah man since your from PA you should checkout DriftPa.com all local people for the most part..but yeah good find I was hoping no one else would see that on craigslist lol....G/L with the car anyway
the problems with the car are:-Cracked windshield $100 fix -Oil leak...
If I let it sit somewhere for a little while after running it. There is about a tennis ball size oil spot on the ground also a few more spots around it. Anyone have any ideas? The fan was all gunked up and grimey.
I bought a new oil sending unit, and front main seal. Hopefully that will fix it.
When i start up the car if it sits for a good 15+ hours it'll start almost like the battery is shot (it is an olllld battery) But also it will only continue to run if i give it throttle for about 5 seconds. If not it dies. Then it'll idle smooth and no issues what so ever.
Car runs and drives great, just that problem at start up and the oil leak problem. Any input would be great on these issues.
And the tanabe coilovers are pro sevens i believe. they have a very nice feel so far.
White Comet
Car: fc, s13 and mazda6, Sierra
saw the car in person today and it looks pretty good. the car def needs a little tlc but its in good shape in general. the paint is in nice shape but its def not an SE. no lip, 4 lug, black faced gauges etc. and teh diff doesnt have an lsd sticker so i am certain its not an SE, but its ok it was a steal. has tanabe front and rear strut bars and tanabe pro coilovers. the tint is crappy but the interior is very clean looking. i vote for ditching the wheels but i like the silvia badges.
btw let me know when you want the front windshield done, i know a guy that does great glass work for really cheap. he did my rear qp glass. i found him in the phone book but he ended up being a high school friend of my dad's. lol he swapped my rear 180sx glass in for only $75
mmaxeyjr
Car: 1995 s14
Whatever the diff is, it definately feels 100X better than the s13 stock diffs. Insurance will do it for $100. Idk if your buddy can do it cheaper? haha
I'm gonna need some help fixing my leak though...
mmaxeyjr
Car: 1995 s14
i attempted replacing the front main seal. everything went alright until I tried putting the new AC belt on. I could not get it on for the life of me. So i put the power steering and alternator belts on and put stuff back together. I tried to start it and it wont start. I hope its not from all the pressure washing I did in the engine bay. Maybe I tightned the pulleys too tight?
it goes to crank but it seems like theres a loss of power and it stops then tries to start again constantly (tries.. stops.. tries... stops..)
i did replace the spark plugs with ngk iridium IX though.
mmaxeyjr
Car: 1995 s14
fixed it. must be bad battery or poor connection... oil is still leaking from somewhere or all the old oil is still coming out after the engine gets warm it loosens and drips? (sound logical?)
mmaxeyjr
Car: 1995 s14
got it fixed but i must need a new battery..
Dazzla
If your title states it is an SE. Then it is. I have the same car, basically from my research Nissan had two SE models.
One was the SE we all know - lip, 5 lug, white guages, and one was essentially a base model with a SE badge or a "base" SE.
I bought my car from the original owner who was an old lady, there was no way she put on a SE badge for no reason. Yet I still have 4-lug and everything you have. + the spoiler
mmaxeyjr
Car: 1995 s14
Dazzla wrote:If your title states it is an SE. Then it is. I have the same car, basically from my research Nissan had two SE models.
haha sweet! sounds logical to me
White Comet
just because the title says se though doesnt mean it is. the title for my first s13 said le and it def wasn't
mmaxeyjr
Car: 1995 s14
true as well.. oh well it doesnt matter to me anymore. i like it and that's all that counts
White Comet
^ i agree. but i'd bet money it's not an se
mmaxeyjr
Car: 1995 s14
When will you be available to help install those tension rods? Also I picked up s14 fog lights would you have any idea how to get those working? I saw you replied to a few posts about them. Do you know how to wire reverse lights as well?
Dazzla
White Comet wrote:^ i agree. but i'd bet money it's not an se
There is a such thing as a base "SE" trust me on that. It is pointless because its not what you expect from a SE lol
DustyS13
Car: 1992 s13 Coupe
CLEAN CLEAN CLEANVery nice find
White Comet
Dazzla wrote:There is a such thing as a base "SE" trust me on that. It is pointless because its not what you expect from a SE lol
that may be, this s14 has base cluster and everything else you'd expect from a base, but my point was that just cuz the title says something doesnt mean its correct.
padgettboy240
Car: 89 240
man this car is clean... very nice!
mmaxeyjr
Car: 1995 s14
thanks
GF just made me a new shift boot
turned out pretty good.
check out my problems post zerothread?id=432959
S13D.W.A
Car: 1989 240sx Coupe
Nice and clean... The rims not sure about those
mmaxeyjr
Car: 1995 s14
thanks man. the wheels arent THAT bad, better looking in person definately. wheel spacers for the rear are a must eventually..
Today I replaced my oil pan gasket with a felpro cork gasket and some rtv black silicone gasket maker hopefully it holds, put on a z32 (big a**) fuel filter, put in new tension rods with energy suspension bushings in them, cleaned up the bottom of the engine bay a little, put on a grounding kit with 2g wires, found out my starter problem is due to my battery being bad, aligned my front bumper a little better. It was a busy day...
I'm letting my oil pan cure until to tomorrow then it should be good to go with a fresh filter and oil.
TroubleBound
Car: 1992 240SX Hatch
Nice car, very clean. I like the kouki's a lot better but yours is nice for a zenki =)
And your shift boot is sweet, im jealous i want my g/f to make me stuff for my car haha. I'll be like 'so you know...my shift boot is getting pretty worn...'
What did she make it out of? Looks nice.
s14derrick
Car: 1995 nissan 240sx
i know you asked about how to get the oem fogs going. if it hasnt been answered..... all you need is to get a relay and the headlight stalk with the fog light switch.swap stalks, install relay, mount lights, plug into factory harness and your good 2 go .
mmaxeyjr
Car: 1995 s14
wanna sell me a stalk and relay? they all seem WAY over priced...
the foglights i got were sent with the jdm brackets not the usdm ones someone should make a write up on how to fab them to work.
i got my s14 fogs for $30 shipped
