Shift__BODOM »
https://forums.nicoclub.com/shift-bodom-u20648.html
Tue Apr 08, 2008 3:41 am
If you haven't tried just revving it a bit to pop the thing out, try it. Might work, and would save you a lot of hassle. Just make sure you undo the bolts first so you aren't pissing into the wind
If that doesn't work, hitman's idea would probably be the best. If all else fails, you could try sticking some kind of chisel in between the exhaust/silencer and pry it out. You'd end up damaging the silencer, but who needs it anyway.
Forgot to mention, revving it to around 2000-2500 did it for me. You might need to go up to 3k if it's as stuck as it seems to be.
