Just got a 96 240SX SE, what mods first for performance?
tjblack
Car: 96 Nissan 240SX SE
Well....I just got a 96' 240SX SE from my sister, its been in the garage for the past 6 years with only 70k on the motor. No leaks, well maintained, all service records. About as clean as they come. I wanted to know what I should do first for better performance on the motor, whats the "Best bang for my Buck" until i can replace the motor with something with a little more power. I'll post some photos soon of my project "BLACK OUT".
simmode1
Car: Red '95 S14
If it's bone stock, you're not ready to mess with the motor. Focus on handling first.
-Coilovers & Master Bushing kit with subframe bushing-brake upgrade.-wheel & tires. I prefer 18x9.5 all around on S14's.
From there, you could choose to stiffen the chassis more with additional bracing or continue building up your suspension to handle the power you want to eventually make. Bolt-on's to the KA are pointless unless you're bolting on a turbo or a supercharger, so forget the N/A route.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Then turbo the stock motor.
whoareu
Car: 1993 rb25det s2 240sx vert
if your going to do an engine swap, why waste money on the stock motor? your not going to see much of an improvement over factory. my advice is do suspension first then do the swap.
tjblack
Any suggestions on what type of coil overs to go with?
simmode1
Car: Red '95 S14
whoareu wrote:if your going to do an engine swap, why waste money on the stock motor? your not going to see much of an improvement over factory. my advice is do suspension first then do the swap.
Proof that even ppl with low post counts can deliver wisdom.
tjblack wrote:Any suggestions on what type of coil overs to go with?
Stance LX+ or GR+(pro)Fortune AutoPowered By Max with 8kg/6kg spring ratesBC Racing Type BRKTS Ultra Lows
There's lots to pick from. But these are the only ones I'm considering. All around $1000 to $1200.
juse
Car: 1990 240sx
check out the coilover thread on here to get some ideas
simmode1
Car: Red '95 S14
^^^Ahh hell yeah! That thread is awesome...
zer...76908
allenms240
Car: 1991 Nissan 240SX
FirstI saw get used to the car before anything. Get to feel the car and know it alot better.Then start with suspension modsThen brakesMotor/interior/exterior
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
is there really a need on his car for such a HIGH end coil?
dude would most likely be fine with a megan street or a Tein Basic etc.i agree with what the others said though, do some suspension if you dont need/want to go really low just get a good set of springs/shocks for the car. you'll have alot of fun with the car like that. Unless your planning on tracking the car alot or doing hard street driving your stock brakes are fine. maybe just run a better pad.
that's my .02
n00b240
Car: '03 6MT
Damn Simm.... KTS ultra low's?? The regular ones aint low enuff for ya? I thought the ultra lows dropped the 240 bumper to the ground. At least thats what the website makes it seem like
EDIT: That coilover thread is win!! Thanks for the link
Modified by n00b240 at 7:43 PM 3/22/2010
simmode1
Car: Red '95 S14
Flicktitty wrote:is there really a need on his car for such a HIGH end coil?
You consider those high end coils?
I consider them entry level... Megans are fine too, but way bother when there are coils with better build quality just about $200 away?
I don't even bother looking at stuff like Tein Basic. Again, just a few hundred dollar would get you so much more...
n00b240 wrote:Damn Simm.... KTS ultra low's?? The regular ones aint low enuff for ya? I thought the ultra lows dropped the 240 bumper to the ground. At least thats what the website makes it seem like
Well, I've never seen pics of the regulars maxed out. The only pics I've seen are OK, but I'd rather have the ability to go lower and not use it than want to go lower and not be able to... The middle level of KTS are cool, but the rears won't go as low as the front from what I can tell...
n00b240
Car: '03 6MT
Seen. Thanks man
Flicktitty
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
there not HIGH END. there most likely higher end money then what he needs. honestly a megan,fortune,ksport,etc is decent for anyone wanting to go lower and handle better.
i got Megans and there just fine and dandy.
riprodder
I've had good experience with Stance coilovers. They are competitively priced and offer a lot of bang for the buck. I've been running them for a year on another car and they haven't given me any grief.
Also if you are looking to perk up the KA a little bit while you're deciding on another engine, you might think about a used intake and exhaust setup. If you buy in low and sell the parts when you do your swap, it won't really cost you hardly anything to have a little more power in the meantime. Another trick you could do is to bump your ignition timing a couple degrees. That will give you more power in the low to mid range.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
+1 on megans
I'm getting Tien tie rods, pillowball are a little too much imo, and getting the energy suspension bushing kit. After that I'm start saving up for turbo
simmode1
Car: Red '95 S14
Flicktitty wrote:there not HIGH END. there most likely higher end money then what he needs. honestly a megan,fortune,ksport,etc is decent for anyone wanting to go lower and handle better.
I don't mean to discourage anybody about Megan. I think they're just fine as well. In fact, I consider them in the same category as the others that I listed... just at the lower end of the scale. Still very decent though.
