just got a 240 wit rb20, LOTS of questions!
dwnshfter
Car: 91 240 rb20
the clutch is gone, i need one asap! where can i find one, noone i have talked to, exedy, summit, or centerforce know what i am talking about. also, i have a rb25 computer, and need a 20 cause the idle is WAY messed up. where to get that? and last but not least, i have no ac, heater or power steering, are there much power losses with them, and how hard are they to install?
rustbucket
Car: '90 s13 RB25DET SII
Hate to be an A$$, but if you use the SEARCH BUTTON you will find the answers to all your questions and welcome to NICO.
Eikon
Car: 71 240z, 93 Supra TT
dwnshfter wrote:the clutch is gone, i need one asap! where can i find one, noone i have talked to, exedy, summit, or centerforce know what i am talking about. also, i have a rb25 computer, and need a 20 cause the idle is WAY messed up. where to get that? and last but not least, i have no ac, heater or power steering, are there much power losses with them, and how hard are they to install?
Um... Hi.. Welcome to NICO! As stated above... the search button is your friend.
Ebay is also your friend!
You will be able to find a RB20 clutch pretty easily on ebay. Here's a nice stage 3 clutch kit.. http://cgi.ebay.com/ebaymotors...QrdZ1
As for your ECU... are you sure you have a RB25 ecu? I wouldn't think the car would run at all on that? But I could be wrong as I've never tried it. More than likely your problem with idle is caused by a dirty/stuck AAC valve and/or improperly set TPS sensor. I'd work on those first before spending moeny on an ECU.
Keep your eyes on the classifieds sticky on the top of this forum.. you'll probably find an ECU on there.
No AC is normal. No power steering is common. No heat???!!! That is very strange? Are you sure the heater core isn't removed or blocked off? Do you know if the water pump has been replaced?
Who did you buy the engine from? Who did the swap?
Shocker
Car: 89 240sxHB rb26/30
lol, what a 1st post, clutch like they said ebay... spec makes them, computer get a stock rb20 one..... yeahhh.. heat doesnt work? you sure the motor is up to operating temp when you try it?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Heater core lines probably weren't hooked up (just looped together). Look for the FSM on the stickied posts and look which lines need to be reconnected to the stock heater core.
AC will not work... good luck on that one. You need to research that one yourself, then hit up a good AC shop for options. Very few people have AC here, like ten.
Search and read your a$$ off!
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
damn this guy told you it had a skyline motor and you bit hook line a sinker didn't ya loll
maroon240
Car: Cyan 95 S14 sold
91 hatch s13 sold
84 300zx 2 seater sold
99 pontiac grand am gt current DD
http://www.takakaira.com for clutch
No ac lines is no hp loss it's like a 2 horse power gain.
there is some way to set the idle i don't know your on your own wit that.
good luck and post some pic.
Aaron
Chaos the Xile
Car: 1974 Datsun 260Z
If you want a cheap reliable clutch get eth XTD Stage 3, Its awesome I have used them in both of my swaps and had no problems from them.
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
A 90-96 300zx na clutch is the same is it not. You can find one of then anywere in the states.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
yeah, im running a RPS street clutch for a NA 300z. works great and easy to findnow for lightweight flywheels you can't use a 300z because of the crank bolt pattern. nengun.com has some nice jun flywheels though
Darius
I have the RPS Max 6-puck sprung clutch and it is easy to operate too. I was shocked at how light the pedal is considering it is rated to 550 ft lbs of torque.
Carl H
the spec stage 3 i bolted to my rb20 is capable of 515ft/lbs at the crank, has light pedal pressure for that rating imho.
Shocker
Carl H wrote:the spec stage 3 i bolted to my rb20 is capable of 515ft/lbs at the crank, has light pedal pressure for that rating imho.
ftw.. im rocking the same exact clutch, peddle is hardly harder than stock, and it hooks like a bastard.
dwnshfter
Car: 91 240 rb20
sorry i've been gone so long, computer is swapped now, it runs like a champ. heater hose is looped, and didn't know if there was a reason besides lazyness for that, and i was planning on the 300zx clutch, but tophat said the br clutch was WAY better.........but 200 bucks more. i am searching the forums as this is not my first forum (i am VERY big on the focus) but this i smy daily driver and didn't have time so i had to ask a lot of retard questions real fast.
