Jesda »
https://forums.nicoclub.com/jesda-u7038.html
Sat May 10, 2003 10:01 am
I just bought a 92 Q with 169k. I am wondering what items I should immediately replace/fix with these model/years?
I did an oil change. Full-synth Mobil1 with a genuine Nissan-Infiniti filter.
Added a "medium duty 16000GVW" transmission cooler.
Rotated tires (replacement soon).
I will eventually have the chain guides done. But at 169k if it lasts this long they likely were done already? Didnt most go out at 120k?
Soon will do transmission mounts, since I notice a vibration when I downshift and accelerate -hard- from 65-80mph (doesnt happen at lower speeds).
I also intend to recharge/repair the AC and do a tuneup.
Then there's the pesky front Bose amps! I always hated Bose for home, now I hate it for mobile...
Last owner (I have records) did a fuel pump, all injectors, egr gasket, heater hose, acc gasket, alternator, all belts, all within the last 2 years/20,000 miles.
A week after I bought it, I had the belts tightened, then the tensioner pulley bearing seized, causing the water pump belt to snap off and my car to overheat briefly. Had it towed, got a cab home, and got a new power steering belt and bearing installed.
Anything else I should have done to get me beyond 200k? I'm taking her across the country (from Spokane WA to St Louis MO) next month.
Thank you!-Jesda Gulati
