yeaboii wrote:I just purchased a 2001 maxima and found that it as really big gas hog(aound 300 miles on a full 18 gallon tank). Is this common for all these models or is there something I can do?
Thanks, I will check the air filter, the tire PSi should be good I think, and I have SES light which is not a sensor failure. I haven't done any of the services, since I just recently got the car. So far I have replaced the spark plugs.MTZI30 wrote:ouch 200 miles! Sounds like you may need a little service. Make sure your air filter is clean, check tire psi, if you have no SES light then yuor sensors should be ok. Have you done all of your serviceS?
