michael_grigoras wrote:alright so i just replaced the chain guides chain timing cover and crankshaft also replaced o2 sensor all 4 fuel injectors the wire harness to the fuel injectors the air flow meter the spindle to the oil pump the radiator and i adjusted the spark gaps but after about 5 minutes of driving the car and i get to a red light when i push the accelerator it stutteers and dies on me but when i get it going and speed up it switchs gears easy and picks up speed so idk if its either the fuel pump a faulty wire on the harness or one of the injectors are bad idk and and suggestions will be greatly aopreciated
I would recheck the wires, make sure the ground is on sercure, and check your distruber, and spark plug wires.
also check to make sure you are getting over 7 amps on your fuel pump. (normal is about 12 or so but I could be wrong)
