Just Finished The Swap, Having Some Problems........PLEASE HELP!!!!!!
trivialchow
Problem Solved!!! running really good
Modified by trivialchow at 10:01 PM 8/7/2007
trivialchow
HELP!!!
GTS4-R
Car: my feet
mafs wiring
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
93Niss240 wrote:mafs wiring
Double check your MAF wiring as stated above. Black/White Wire is 12Volt (power wire).White Wire is 0-5V Signal (the wire that sends the signal to the ECU)Black wire is ground. (grounded at the ECU but can be grounded anywhere)Yes this is quoted from otterman but its right and I am lazy
cheapscheisst
Car: 1996 240sx w/ Kouki front end
is your engine well-grounded. this can cause similar problems.
trivialchow
Updates:
I check and the ignitor chip wasnt plugged in all the way. once it was plugged in properly the motor ran fine and idles prefectly. the only thing wrong now is that the car still wont rev pass 2,500 rpms. do you guys no anything else besides the MAFS that might cause this. please let me know.
-thanks
GTS4-R
Car: my feet
how many times do we have to tell you....IT IS YOU MAFS and/or MAFS WIRING!.... hard wire the signal form the mafs to the ecu with a fresh wire and make sure the mafs has power and ground.... that'll at least tell u if its the wiring or not
nipo
Although, none of these problems problems deal with me, i think its helpful to the board if you post the solutions to all your problems. Saying its fixed doesn't really help anyone down the line. Say these guys the aggravation of having to answer questions over and over.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Well, if you read the whole thread you will find out how he fixed the problem
GTS4-R
Car: my feet
ps i want those wu and rage tickets...if u give em to me ill come down and fix ur sr
trivialchow
93Niss240 wrote:ps i want those wu and rage tickets...if u give em to me ill come down and fix ur sr
lol
