Well, after having all of the parts for about a year, I finally turbocharged my S13. My brother and I were able to use the shop where he works, because everyone was in Moab for a few days(It's a 4 wheel drive shop). We decided to finish the car while we had the shop to ourselves. I made custom brackets for the intercooler that bolt to aluminum nuts that were welded to the intercooler. The intercooler piping was made from mandrel bends and straight pipe that I cut while my brother welded. We TIG welded the JGS manifold, and MIG welded all the piping. The turbo is a T3 from a Z31 that I bottom mounted because of the design of the turbo outlet. I'm running a blow through MAF, and my intercooler piping is a little different, because I did not relocate my battery. Well I guess that's the basics. Running stock boost, the wastegate opens at 5-6psi. I'm running it very rich right not until I can get on a dyno and tune it.
Pics of the turbo install can be found here.
http://home.comcast.net/~trick...s.htm
General info about my setup can be found here.
http://home.comcast.net/~trickmotorsports/
