Doya »
https://forums.nicoclub.com/doya-u130627.html
Sun May 23, 2010 2:07 pm
I just finished my 5 speed swap in my s14 and I'm having a bit of a problem. When the car is running, and I put it in gear, it dies. But if I start it up in gear, it stays running. I should also mention that when it's running, it is REALLY hard to put it in gear. I've done two swaps before in s13's and never had this problem.
I was thinking I might have wired my clutch pedal in wrong. I cut the green and black wire on the sensor on the left side of the brake pedal and connected each end to the sensor on the back of the clutch pedal bracket. Is that correct?
I'd appreciate any help.
