kim »
https://forums.nicoclub.com/kim-u15840.html
Fri Apr 30, 2004 2:36 pm
I just did a smog test today and failed. the Tech said the carbon level jumps up and down, at times it would be at passing levels and others it would jump up to failing levels. What would cause this? If it helps the carbon level went up to 6 points (I don't know the scale).
Also I told the tech that the engine hasn't been used for a while. The story is, I got the car from a friend, I found the engine at a towing yard, it is off a 240 automatic trans car. Right now I don't have the A/C belt on, because the previous owner took out the condenser and dryer. I will eventually get those things but right now I trying to pass smog. The car has NEW O2 sensor and new CAT.
Last thing the tech told me if the engine has been sitting for a while. I should put fuel injector cleaner in it and drive it for a while then it might pass.
Any suggestions?
