Just did Trans service. HELP!
SarcasticaLy
Car: 2001 QX4
Hey guys, I just did the Trans fluid flush and filter replacement. Now when I'm stopped for awhile, it will feel like the transmission isn't fully engaging. Revs high for a little bit then it will catch and be normal. I checked the fluid and it was a little bit low and I added more but it still doing the same thing. Any ideas?? Thanks.
SarcasticaLy
Car: 2001 QX4
Sorry. 2001 QX4. 4WD.
4xq
Put it in reverse, leave it there for 30 - 40 seconds, then go to d1, and on up one by one. 30 -40 seconds at each gear..
That should get the fluid to work its way thru the transmission.
SarcasticaLy
Car: 2001 QX4
So I drained a bit n corrected the fluid. It seems like it's back to normal. I didn't know it was that critical for fluid level. We'll see if it holds up. It should. Thanks 4xq! I'll do that too.
