gixxerbob »
https://forums.nicoclub.com/gixxerbob-u80630.html
Wed Dec 17, 2008 10:17 am
i guess 350 with a nice lag at 18psi, maybe more hp at a high rpm
i think the gt2876r is going to be quite laggy though without some cams.
y not a gt2871r .64 or disco potato, what boost are you planning on running with all these new studs/gaskets/bearings?
a codyace inspired build could yeild 400hp with most of the stuff you already have and spool fast as as a motha.
since you did main studs and rod/main bearings what kind of pistons did you use? please told me you did pistons
recirculate the bov.
why does your hot pipe look like it is 2 inch?
and y in the world did you put the intake directly behind the radiator?
(get a bigger hot pipe to flow more and to better fit your intake behind the headlight)
realize that no power steering is annoying for the street
just my 2 cents
Modified by gixxerbob at 12:32 PM 12/17/2008
