Just did the Q45 front caliper upgrade and... (comparo inside)
TheRealNap0le0n
Car: 1998 q45
all i gotta say is Q45 brakes ftmfw!
$70 for both front calipers (egay) and $80 for both front rotors (advanced auto)
drilled the rotors for 4lug myself.
bolt on install ( USE THE FACTORY 240sx CALIPER BRACKET BOLTS!!! the Q45 ones are too long and will hit the rotors ) The Q45 calipers dont need any conversion lines like the Z32/Skyline calipers and they clear any wheels including steelies. you have to remove the dust shields to clear the rotors.
car stops like OMG so yea.... no pics cuz i was too lazy to bring the cam out and dont like touchin it when im dirty.. i can take pics later tho...
best part is the VS
-----------------------Stock 240SX-----Z32 Turbo-Skyline GT-R (R34)-'90-'96 Q45 Rotor Diameter:-----10 inch-----------11 inch--------11.6 inch---------11 inchRotor Thickness:-----18mm------------30mm-----------32mm-----------28mmRotor Weight:--------12.5 lbs---------17.5 lbs----------19 lbs----------17.5 lbsCaliper Type:-------1-pot sliding-----4-pot fixed-----4-pot fixed-----2-pot slidingCaliper Weight:--------9.5 lbs--------6.5 lbs (alum)----6.5 lbs----------11 lbs-------------------------------------10lbs (iron)
Pro's:+Bolt on+low cost+better heat capacity than stock+better clamping force than stock+clears stock wheels+larger pad surface than Z32
Con's-not as baller as Z32/Skyline brakes-weigh more than z32 alum set up-sliding calipers look gay compared to fixed calipers-less aftermarket options for pads than Z32
alot more good info on brake swap options can be found http://my240.epijunkie.com/5_Lug_and_Z3 ... ke_Booster
Modified by TheRealNap0le0n at 9:57 PM 1/25/2010
Modified by TheRealNap0le0n at 10:38 PM 1/25/2010
Modified by TheRealNap0le0n at 10:41 PM 1/25/2010
Modified by TheRealNap0le0n at 10:42 PM 1/25/2010
Modified by TheRealNap0le0n at 10:43 PM 1/25/2010
locoluna825
Car: 90 240sx coupe
no pics??
TheRealNap0le0n
Car: 1998 q45
ill take some tomorrow... gosh...
random myspace found thru google search lol wrote: q45 calipers
Quote » stock calipers [/quote]
P_856
Car: s13
i need to drill my rotors to 4 lug i was wondering what size drill bit to i need i think?
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Yeeees, Q45 brakes are so good. If you want to make the bias feel better get a master cylinder from a 1989 Turbo 300ZX (Z31). It's the exact same as an S13 BMC but is bored out more so it'll move more fluid. I did that with mine and really helped out.
Great comparison, by the way.
ALSO, if you don't want to drill the rotors yourself, contact Travis at 88Rotors and tell him you want Q45 rotors drilled to 4x114.3. He just gets blanks and drills them out in house.
swpS13
dumb queston...but do you guys upgrade the rear too as well? I'm planning on doing this setup for my s14 too. And great to know they're bolt on. i was just about to search that. Thank you
Modified by swpS13 at 1:19 AM 1/26/2010
Gabes13
Car: rb20det s13
No side by side caliper shots?
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
all i found was j30
TheBlaiant
Car: Slow40sx
Napoleon I just noticed you live in my town lol.
youngun21a
Car: 240sx 1993 Automatic
I about to do the same setup..just waiting of the Rotors from egay there q45 4 lugs and got them for 70...before anyone say there are no 4 lugs q45 rotors there custom made for 4 lugs...so just waiting on them so i can do the install...Hope to get them soon so i can do it on the weekend..paint and sand them...
ILoveMyRHS13
swpS13 wrote:dumb queston...but do you guys upgrade the rear too as well? I'm planning on doing this setup for my s14 too. And great to know they're bolt on. i was just about to search that. Thank you
No, you don't need to do the rear brakes.
By the way, J30 brakes are the same.
TheRealNap0le0n
Car: 1998 q45
P_856 wrote:i need to drill my rotors to 4 lug i was wondering what size drill bit to i need i think?
I did mine the lazy way... i can go get the drill bit size but all i did was place the new rotor on the ground and then the old rotor on top so the hats were touching, i lined up one of the wheel stud holes and then spray painted the rotors so i could see where the other 3 hole were gunna be on the 5 lug rotor.
I then grabbed IIRC a 1/2" bit ( it fit in the factory lug hole really nicely ) and a smaller bit ( maybe a 1/4" bit). I used a center punch to mark where to drill and then started with the smaller bit. The smaller bit will stay in the center punch and drill truer without moving around as much. after i drilled my starter holes i moved on to the larger bit.
once that was done i test fit the rotor on the hub. The first rotor was ever so slightly off so i had to slightly enlarge the holes ( i was just eye balling the placement ). The second rotor went on the first time perfectly.
I honestly recommend getting rotors that are professionally modded unless you are good as fabrication... i drilled mine as i didnt have the slight extra money to purchase 4lug modded rotors and i didnt want to wait for mail order parts.
TheRealNap0le0n
Car: 1998 q45
IIRC the rear is bolt on too but to be honest I'd save up for something more substantial like Z32 rears
pandapants wrote:No side by side caliper shots?
numbnuts240 wrote:all i found was j30
Thanks... from what i read J30 is the same as Q45
youngun21a wrote:I about to do the same setup..just waiting of the Rotors from egay there q45 4 lugs and got them for 70...before anyone say there are no 4 lugs q45 rotors there custom made for 4 lugs...so just waiting on them so i can do the install...Hope to get them soon so i can do it on the weekend..paint and sand them...
I thought about painting mine as they were dirty lookin but i still have steel wheels so you cant see the calipers anyway and my stock caliper was leaking like a sift
TheRealNap0le0n
Car: 1998 q45
TheBlaiant wrote:Napoleon I just noticed you live in my town lol.
Yea lol... i havent seen you around.... theres a 240 meet on monday nights, usually about 15-20 240's
where in miami? my girl live in pembroke pine/ hollywood so im down there alot too
bersh240
nice triple post..and does your steering wheel shake at higher speed?
swpS13
napoleon, did the caliper you got off ebay remanufacture? is it okay to get remanufacture q45 caliper?
bersh240
swpS13 wrote:napoleon, did the caliper you got off ebay remanufacture? is it okay to get remanufacture q45 caliper?
i got junkyard j30s.they work perfect. why would you buy remanufactured when yuo can get juckyard ones for 20 bucks and rebuild them yourself?
TheRealNap0le0n
Car: 1998 q45
bersh240 wrote:nice triple post..and does your steering wheel shake at higher speed?
I know right... TRIPLE POST FTW...
no vibrations or shakes at all
TheBlaiant
Car: Slow40sx
TheRealNap0le0n wrote:Yea lol... i havent seen you around.... theres a 240 meet on monday nights, usually about 15-20 240's
I know about the 240 meets lolWhen i'm down south i'm around kendall,Holly Hood, and Okie lolI drive a silver hatch that had umm....blue wheels It's sitting now i'm driving my dads Slammed S-10.
TheRealNap0le0n
Car: 1998 q45
might have seen it around lol...
yea im usually lurkin around university area in miramar and hollywood
TheBlaiant
Car: Slow40sx
Do you have a brother thats gone thorugh about 24984534 Camaros buy any chance?
White Comet
Car: fc, s13 and mazda6, Sierra
ILoveMyRHS13 wrote:ALSO, if you don't want to drill the rotors yourself, contact Travis at 88Rotors and tell him you want Q45 rotors drilled to 4x114.3. He just gets blanks and drills them out in house.
hmm i didnt know that. any idea how much he charges for em?
youngun21a
I got my for $70 Drilled & Slotted for 4 Lugs ...brakemasters
bersh240
White Comet wrote: hmm i didnt know that. any idea how much he charges for em?
i got front rotors and pads from him for $106
ILoveMyRHS13
I paid $110 shipped for pads and rotors. Well worth it, f*** drilling out rotors again.
TheRealNap0le0n
Car: 1998 q45
TheBlaiant wrote:Do you have a brother thats gone thorugh about 24984534 Camaros buy any chance?
hmm you know steve too haha... wait... you rock the x-mas tree on you tow hook?
ILoveMyRHS13 wrote:I paid $110 shipped for pads and rotors. Well worth it, f*** drilling out rotors again.
meh took me like 10 mins a side to eyeball mark and drill but im not gunna worry about it because the next mod i do will be 5 lug conversion, i just need to find some 15" maxima steelies or some equally cheap 5 lug wheels.
TheBlaiant
Car: Slow40sx
You mean the air fresher?I had that a while back with brandon's S14 lol
TheRealNap0le0n
Car: 1998 q45
small world haha
TheBlaiant
Car: Slow40sx
Tell me about it lol
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
J30 brakes 4 life! Great writeup thread w/ specs yo.
