Ed.williams5 »
https://forums.nicoclub.com/ed-williams5-u263945.html
Mon May 16, 2016 7:43 pm
So I just finished replacing the clutch on my rb25 with an act ns3-xtss. Replaced slave cylinder, clutch pedal bracket and adjusted Cmc pushrod. So let me start from the beginning and hopefully someone can chime in and point me in the right direction.
I had to adjust the Cmc pushrod because it was too far out and wouldn't relieve pressure off the slave. Gravity bled the slave through the bleeder then operated slave by hand to get air out (did this until bubbles stopped coming out of Cmc reservoir). Even after doing all this the clutch pedal is still really soft especially for the pressure plate I have installed. Now for the odd part may just be coincidence.
Have the car running on jack stands I can go through 1-3 without using clutch, tires are spinning so clutch is engaging. 4-5 I can't get into gear with/without clutch. So my question:
Does this sound like I need to rebleed the system or do I need to look elsewhere?
