just did 300zx front brake swap
RIghtwinger1322
Car: 1992 240sx
i just finished doing the 300zx front brake swap and i swapped the master cylinder and now the ebrake light on my dash wont go off, anyone know what could cause this?
SirSilvia
Car: Sold both my babies
for front brakes it shouldn't matter but if you had the e brake on during the swap then maybe a shorted out lever switch?Mine wouldn't go off and it was the little switch on the lever that wouldn't "let go" and i ended up juts taking out the bulb.
motoman399
Car: 98' wrecked (RHD coming soon) 240
sounds like its something to do with the fluid sensor in the master cylinder. maybe its bad. dont thing it has to do with the ebrake.
ZOMG.SR20
Car: 1990 s13
low on fluid
RIghtwinger1322
Car: 1992 240sx
its not low on fluid i know that for sure. i guess ill just have to unplug that light before it drives me crazy
Scuffed_ChukiCoupe
Car: Ka-t coupe
Check the cable/sensor under the center console thingy. It gets touchy alot... been that way in all my 240's. Theres a screw there that might need some tightening.
Hijacker
Car: '92 240sx Convertible
'94 F-150
The float is probably just stuck on something. Try manually moving it in the MC and see if that solves the issue
sloweighty
Car: sileighty
couldn't you just keep your stock brake master cylinder. The reason why i say that is because i have heard a lot of people saying that if you are just doing the fronts then you dont need the z32 master cylinder but if you are doing all four the you would need the z32 master cylinder. (correct me if i am wrong)
94_240sx
Car: 94_240SX
sloweighty wrote: couldn't you just keep your stock brake master cylinder. The reason why i say that is because i have heard a lot of people saying that if you are just doing the fronts then you dont need the z32 master cylinder but if you are doing all four the you would need the z32 master cylinder. (correct me if i am wrong)
Sounds about right. Yeah, OP, you could have kept s13 BMC.
Arashi
Car: '93 240sx LE
I'm doing my 300zx brake swap this weekend and I'm keeping my stock BMC
RIghtwinger1322
Car: 1992 240sx
light went away..the float was probably just stuck..
and ynot go with the bigger bmc it was $60 and incase i decide to upgrade i have it.. so now i just have a really stiff brake pedal
thanks for the input
SirSilvia
the e brake light has nothing to do with the BMC
Scuffed_ChukiCoupe wrote:Check the cable/sensor under the center console thingy. It gets touchy alot... been that way in all my 240's. Theres a screw there that might need some tightening.
that's more likely the problem. the e brake light isn't connected to anything on the car except the toggle switch on the lever itself. Unless anyone can show me otherwise on the schematics itself.
As for needing the z32 BMC its debatable, they are bigger rotors, but the caliper has more leverage so less effort is needed to grip. then again there was some pretty useful info on all that here zer...48666I got learn'd lol, good info
