SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Thu Aug 05, 2010 5:50 pm
That sounds like an awful but kind of fun project.
the output shaft would have to be swapped for a custom fabbed adapter. Unless it were to be a perfect (within 0.001")match a new set of drive shafts might be needed, along with mounts and a few other things.
Wiring wouldn't be as much of a problem since the only wires on an MT are the reverse position sensor and tail shaft speed signal. There are no CAN lines running into the trans as they are on an MT....However that brings up a whole new set of issues. The ecm would have to go, but there is no AWD MT in the states so finding an ecm that would not only run without a check engine light but even start would be a challenge.
If I had to guess at a total price I would say 8-10k maybe less but most likely more. Labor would be the biggest factor, if it were a diy project it would probably take a month at least in ideal conditions.
-Hey OP- What are you bypassing?
