Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Wed Sep 24, 2008 6:23 pm
Just make sure to leave some slack in the cables, and adjust them after everything is completely warmed up. The fast idle cam can throw things off if it is still holding the throttle open a little. If you adjust the cables too tight they will bind and you'll have a high idle.
To answer your other question, the rod in the AAC valve is black. I cleaned mine today along with the plenum, throttle body, runners, EGR valve, etc. I have gone trough 14 cans of brake parts cleaner in the last two days. Who knows how many brain cells
Hopefully I will be done with my injector replacement early next week!
Heath
