just changed my spark plugs and my slip/tcs lights wont go off
kidstayridintheq45
Car: 1994 infiniti q45
i have a 1994 q45 and i just changed the spark plugs and after i was done i put it all bac together and it started up fine but then i drove it and both slip/tcs lights are on it feels like its not allowing the car go can any body tell me what this could be thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
did everything get connected on the drivers side?
kidstayridintheq45
everything got connected but on the panel that covers the plugs there is a lil black box they r on both sides and ther is a lil white clip the kinda broke off but ther is no contact points for it
qship96
Car: 1996 Infiniti Q45
check connections at secondary throttle position sensor
kidstayridintheq45
where exactly is the secondary throttle position sensor located
cabal1024
Car: 2005 Q45
Circled(poorly) in green is the secondary TPS.
Photo courtesy Q45.ORG...
kidstayridintheq45
you see that lil white clip thats next to the secondary tps/sensor i broke that lil white clip[ off....i checked the tps sensor and it was fine i guess i blew it out ....when i did the spark plugs i took the sensor and the lil box it connected to off ...could that have any thing to do with it? is there a certain way its supposed to go on...
dix
I have a 94 Q45 88000 miles. The TCS and "slip" lights just started going on when I start the car abnd won't go off. Seems to be affecting transmission. Feels like the engine is braking when I coast as it would if I downshifted. Any ideas?
PachoC
With the engine running, check if there's like a "humming" noise coming from the ABS actuator - left, back corner on the engine bay (passenger side). I had a similar situation and it turned out to be one of the two relays that govern the actuator. If this is the case, just hitting it slightly may get to stop humming. Once you turn the engine off and on again, the lights go back to normal.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Welcome of NICO, dix
Check your TCS relay under the battery tray first.
