AMSOIL makes a great product. i was sponsored by them for 2 years, and its a solid product. i refuse to use anything else in my racebikes. that being said, - i would NEVER use an oil for longer than 10,000 miles in my cars. and that would be after a 5,000 OIL ANALYSIS TEST to determine my wear pattern (some cars wear slightly more or less than others).
yes, oils can go for 15,000+ miles... but thats in a perfectly running engine. the older the engine, the more combustion gasses bypass the rings and into the oil.
yes, filters can go for 15,000 miles... but that too is in a perfectly running engine. and it depends on which filter - as all filters are not the same, and break down after a certain period of time - and unless you take it all apart, you cant tell what condition its in
if your engine has slightly more wear than the AMSOIL test subject, your oil will dirty up quicker, and so will your filter - which will cause your filter to go into BYPASS mode. if your filter gets clogged, it will go into bypass mode, thus no longer filtering the oil; causing you to run dirty oil - further wearing your internal parts.
dont be cheap, nor gullible. buy oil expecting to change it no later than 10,000 miles just to be safe. (conventional oil: 5,000 miles) & (synthetic oil: 5000-10,000 miles)
And make sure you buy a filter specified for higher mileage intervals. many oils can go 15,000+ miles but requires at least 1 or more filters to be changed in that time.
remember just because ABC Co. got great results from using an oil for X amount of miles - doesnt mean you will get the same results / or that its safe to do the same drain intervals. your engine/mileage will yield different results. keep that in mind!
AND DONT FORGET TO ADD OIL AS THE MILES RACK UP. OUR ENGINES NATURALLY EAT OIL THROUGH THE PCV SYSTEM, AND IT REQUIRES US TO ADD OIL EVERY NOW AND THEN. IF YOU DRIVE 15,000 AND NEVER ADDED OIL - YOU FOR SURE RAN IT TOO LOW.
