Just changed my Distributor.........
jkerr240
Car: 93 240 sx
and now that im done, it started making this loud slapping noise, like the timing chain tensioner isnt working correctly, but once the motor gets over 2,000RPM the sound goes away, any clues?
verSat1l3
Car: 93 S13 Fastback 96 S14 SE
jkerr240 wrote:and now that im done, it started making this loud slapping noise, like the timing chain tensioner isnt working correctly, but once the motor gets over 2,000RPM the sound goes away, any clues?
Bad bearing in the dizzy? Are they sleeve or ball bearing...?? Oil pressure light isn't coming on? You got some pieces of the old dizzy gear rattling around in the chain assembly? Hell pull the valve cover and check the tensioner, you should be able to see it/check it with a screwdriver.
clss240
Car: 1990 240sx hatch
im betting your timing is just off. dont forget whne your checking the timing with a timing light to unplug the tps.
jkerr240
Car: 93 240 sx
why unplug it i dont understand that? but we didnt unplug it when we changed it. And no there are not possible parts from the dizzy that could rattle like this and then go away after 2000 RPM. My guess was timing chain tensioner, and now i got the bad chain rattle.
jkerr240
Car: 93 240 sx
Adjusting timing and not unplugging your TPS. what can that cause?
jkerr240
Car: 93 240 sx
anyone?
clss240
the tps job is to send a feedback signal to the ecu so it can just load rating, more load the ecu will then retard ignition timing, unplug the tps while ur timing light is on the marks and you'll see what i mean.
jkerr240
Car: 93 240 sx
Yes i found out today. Just needed to get my hands on a timing light. Timing was set at 20 Btdc, unplugged tps, raced engine a few times, plugged back in tps, now timing is at 15+-3
clss240
still getting the same noises?
jkerr240
Car: 93 240 sx
yeah, im pretty sure the noise is my top chain tensioner, probably stuck or something.
danielsan
Car: 1991 240sx coupe SE
stock timing is at 20.
jkerr240
Car: 93 240 sx
I know, thanks. I just wanted to feel the difference, the timing made. but i feel no difference other than it takes till 2000+ rpm to get going.
