Just changed injectors, now smokes?
clever240sx
Car: Nissan 240sx
ok, i just replaced all the injectors and it started to smoke pretty bad. Well i needed to change the oil, so i did. And i started it up and it ran fine(didnt smoke or anything). But i took it for a 10 mile drive and right when i got back, it started to smoke agian. What is wrong???Please help me out!thanks!!
slipnfall
Car: '06 D40
Did you install both o-rings on each injector? Did you re-use the original orings, or new ones? More importantly, did you lube the orings before re-installed? If not you may have tore one, but I would certainly remove and re-check them all to be sure. Use vaseline on the orings before reinstalling.
