Sentientbydesign »
https://forums.nicoclub.com/sentientbydesign-u25395.html
Thu Mar 06, 2008 2:05 pm
Gavin,
I'm sorry to say it, but I gagged a little when I saw what you bought. I was expecting some ugly chromies with black plastic and you succeeded in further letting my expectations dwindle.
When they mentioned suspension, they were talking about lowering it. All you've done is replace the struts which does a whole lot of ..... Maybe your braking distance has improved, but that's about it.
Also, if you do get lowering springs, make sure the struts can handle it and get camber adjusters. Or you'll be buying tires like they were bubble gum.
I would suggest the 18" G35 rims. They're a little big, but they look amazing on the Max/I30.
Also, going from a 15-16 doesn't do much either. All you see is 1/2 less tires all the way around.
I would personally suggest getting some nice 17s or 18s with wide tires and dropping her an inch or so.
You can probably get a deal by calling around to the various dealers and asking them if they have any blems or take offs. Try to get a set with tires and you'll be good.
