nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Mon May 09, 2016 7:22 pm
Welcome,
Gas tank is more than likely the sending unit. They normally go bad, wear out, etc...
Brake lights come one when you press the brakes, check the fluid, make sure it is full. If not, the third brake light could very well have the wrong bulbs in them, even though it works. They are very specific from Nissan.
Reverse lights are more than likely a switch or a connection at the switch. Can be changed, but an easy task with trans in the vehicle. The wires normally break off at the switch. wouldn't hurt to take a look, if you are able to.
