Buzzman wrote:
Something is not right. The 3.5 should be a lot faster, and it should not be rough under acceleration. Mine has over 210,000 Kms on it, and it pulls strong and smooth. It also doesn't burn any oil yet. Better have yours checked. BTW, did you get any kind of warranty with it?
Hmm...I dont have a warranty. They did offer a one month 500 mile thing but that ran out as I drove almost 900 miles from Texas to Al after I bought the car.
I am actually shopping for an Auto Warranty right now and found one - Warranty Direct. But seems like their total claims' limit would be 6000 bucks only.
Any suggestions on warranties?
Also, I am wondering about a couple of issues.1) Power valve screws. Is that a very common problem? Why are these VQ engiens rated so high if they are bound to get fried cause of these screws falling in.
2) Why do these engines burn oil? I noticed I was a quart low after my drive back. I immediately had the oil and filter changed and plan to do so every 2500 miles or so and will stick with conventional oil as I came across a post that stated that the manual recommends against using SYN.
Is it something to with the PCV valve, this oil burn? Is there a fix for this?
Ive read the threads about using loktite for the power valve screws and am thinking its a DIY for novices and will read up some more and make some notes before I start on it.
Are there any other known and common problems with these engines that one could fix as a precaution?
Thanks for the help.
