Car has 117k miles on it. The people I bought it from (2nd owners) were extremely nice and forthcoming, in a very well off neighborhood. This Q started it's life as an "old lady" car. I don't think it was ever beat on, I think the last owners just neglected proper maintenance.
Regardless of paying a mere 7k for it, this Q45 is my first truly high end car. I'd like to get it back to tip top shape (or close) and keep it that way. It's also my first Nissan, not sure how "they do things".
1st question. Why can't I find my (front) seat heater buttons? That is standard on every Q, right? Book says center console. Am I blind? ...Not the rear seats as I realize this car doesn't have the premium package.
Problems I want to fix immediately (am I on the right track?):
Brakes: pulsation in pedal when pressed, worse at speed. I presume one of the front rotors is warped. Could anything else cause that? Plan to buy a new set of rotors and pads tomorrow.
Engine: Very sluggish initially when you press the gas hard. Sounds like the motor lopes a bit (for about a second). Power kicks in pretty well after that. Similar sluggishness when you press the gas at cruising speeds. After about a second, all is well with acceleration. Needs a standard tune-up is my initial thought on this.
Exhaust(?): Outside the car, I hear an ever so slight sound that correlates with the rpm, harder to hear as the motor's noise level increases. The sound is Indiscernible from inside the cabin. It doesn't seem like a motor tick, it sounds like exhaust noise. Any ideas what else to look for?
Minor issues:
--Tire pressure monitor is acting odd. Reads "???" for all 4 tires.
--Trunk pops but doesn't lift. I presume it should be motorized.
--Burnt out interior lightbulbs: Clock, front passenger, rear passengers (both)
Think that's every issue I've found in two days. Everything else works great. Car drives great as well.
Side note... I love the stereo, but I hate the lack of MP3 functionality. Not even a 3.5mm jack. Looks nearly impossible to replace the stock radio. Can I replace just the CD changer to a newer stock one without a lot of hassle? (assuming newer models could play MP3s) Looks like my only MP3 option would be a cassette adapter. (which would be absolutely tragic in this car, eh?)
Thanks for any help or ideas on where to go from here. Any tips for a 1st time Infiniti owner are welcome. I'll continue browsing the forum as time permits.
-Jerry-
