puck wrote:
Speaking of required maintenance, is there some place I can look up that up? I plan to bring the car into the local Infiniti dealer next week to have looked it over. It would be nice thought to know what stuff needs to be done. I have picked some of it up reading through this board, but haven't found a single location that lists everything that needs to be done and how often. thanks agian!
make sure you change your timing belt every 60k miles otherwise you risk destroying your engine. The engine is an interference design, so when the timing belt breaks, everything goes.
Other than that, do a full transmission flush at about the same 60k mile interval and change the filter. If you want, you can use a synthetic transmission fluid. If you live somewhere where the weather is warm year around and it seldom snows, I would suggest a transmission cooler. Transmission in a warm climate with the weight of the J have shorter lives.
Do oil changes as per owners manual for your region. I prefer running a full synthetic oil with OEM Nissan, Valvoline Max or NAPA gold oil filter.
Use OEM rotors for the brakes, anything else will warp. My preference is OEM rotors with a high quality ceramic brake pads.
Use only OEM Nissan sparkplugs, anything else creates a ton of headaches.
