just bought a turbo kit!!!.. what next???/
maka
Car: Kouki S14
hey dont know if the title makes me sound dumb but i know quite a bit about boosting. but i would like to make sure that i am getting the right info...
i had just bought this kit....
http://cgi.ebay.com/ebaymotors...QrdZ1
and all that i am missing is a fmu or some sort of fuel management. i had also purchased an safc from a friend of mine and am in the process of looking for some 370cc sr20 injectors(just looking to hit around 250-300hp).would that be all that i would need for my turbo to run, besides a proper tune.
i was also browsing and found this...http://cgi.ebay.com/ebaymotors...QrdZ1
i had emailed the seller and asked him if the safc was useless if i purchased the ecu. he said YES.. so my question would be, should i sell the safc or keep it and just use it to tune the TuneD ecu??
any info and advice on what i should do to make my turbo setup run properly and safely would be great. oh yeah.. i know its an ebay kit, but it isnt an SSaC or whatever, i am going to get the turbo re-built by a turbo shop here and he guarantees his work for two years.
thanks org...maka
eazye2000
Car: S13 KA-DET
I think the only thing I could add is that you will need turbo Outlet adapter and oil lines. Along with the fuel management stuff.
And the SAFC is still useful. People use them everyday to fine tune Enthalpy and JimWolf ROM tunes.
maka
Car: Kouki S14
turbo outlet adapter??? oil lines from? to?? doesnt it come with an oil line? i think i might need the return though?
SeanC
Car: 1993 240sx SE
something to keep shrapnel out of your engine.
kornaz
Car: 95 240sx SE.
You know quite a bit about boosting? I suggest read lots and lots more, then proceed to boosting.
TheOne
Car: 93 240sx FB
SeanC wrote:something to keep shrapnel out of your engine.
for when the turbo splits in half due to the epoxy not holding up.(&the blades go right through the intercooler, into the engine, and probably stay in there......but not before it seizes the motor first)
it says in the ebay auction that it doesn't include oil lines.
maka
Car: Kouki S14
kornaz wrote:You know quite a bit about boosting? I suggest read lots and lots more, then proceed to boosting.
lol.. i just want to make sure that i have all my "said facts" straight.. thanks for the flame though. no info.. no post. and besides, i said i know about boosting( purpose, how it works, etc...) does it say anywhere about i know every part. so just read this and be done with the b.s., dont reply dont even bump. late...
maka wrote:hey dont know if the title makes me sound dumb but i know quite a bit about boosting. but i would like to make sure that i am getting the right info...
maka
Car: Kouki S14
ahhhh.. probably one of the most important things to have. thanks for the info.
Riubens
Car: ka-t 240 and 99 Q45 t
hey maka get the oil lines from here : jgstools.com, from the looks of it your only going to have problems with the oil drain line,and yes get the S-afc,370cc injectors and also get a WIDEBAND is a must! and do a lot of research,ALOT,cause I thought I knew alot about turboing a car but when it came to the labor I didnt know squat!so it took alot of trial and error .
DON'T FORGET, GET A WIDEBAND!
maka
Car: Kouki S14
Riubens wrote:hey maka get the oil lines from here : jgstools.com, from the looks of it your only going to have problems with the oil drain line,and yes get the S-afc,370cc injectors and also get a WIDEBAND is a must! and do a lot of research,ALOT,cause I thought I knew alot about turboing a car but when it came to the labor I didnt know squat!so it took alot of trial and error .
appreciate the info and yes, i am pretty sure that i am going to be just like you. but the wideband is for tuning, am i correct.
Riubens
yeap,the wideband is for tuning,but it also lets you know when your car is not running right. you could get the one I have I got it from ebay, just type: ngk afx wideband got mine for 230 shipped .
Chezedik
Car: 1991 Nissan 240sx
1) Your turbo is probably fine, the chinese journal bearing turbos do pretty well. Hell, they're all chinese anymore.
2) A wideband is a type of oxygen sensor that has a larger spread or band associated with it's voltage oscillations. For your purposes, it is an oxygen sensor that will let you know when you are running richer than 12:1, and will do less bouncing all over the place than your stocker. Get one, this is VERY important.
What level of boost are you planning to run? You won't get much out of that T25 so keep it realistic. If you are dead set on getting it rebuilt, have them throw a T3 compressor on it, and maybe a larger turbine. Or you could just do like I would like to do and make a T2 bodied T3/T04e.
Oil Lines are good from CheapTurboLines.com, that's where I got mine.
sleepyeyes
Car: '93 240sx Fastback
sorry to spam your thread but i didnt wanna start a new thread asking a noob question.What are some of the most common s13 turbo kits used(looking for 350-400 rwhp)? Also i know greddy makes one for the s14, would there be a way to make it work on my car or is there a clearance/layout problem. Ive been out of the 240 game since my wreck 3 years ago, dont flame me...
Chezedik
The phrase is thread-jack.
IAP, N-Sport, AMS, Turbonetics, FMAX, Turbo Specialties, etc. You can do a google search and turbochargers.com should have a listing of what they offer.
The initial Greddy kit will work with minor modification on the S13, but the intercooler kit will not. The Greddy kit does not include an intercooler. If you decide to go this route, use the SR intercooler kit available from them for the S13, and it should work with minor modification.
Or you could build your own.
GEO
Car: 95 240sx KA-T
God you probably just brought a headache.
Chezedik
Me, yeah probably.
maka
Car: Kouki S14
ok, so here is what i have....
turbo kit, all basic t25, intercooler, plumbing, etc..walboro fuel pumpfpr370cc sr20 injectorssafc
that should be all i need to get it running and a minor tune for street ... right? am i right, or am i missing something, please let me know cause i dont want to be blowin my **** up at about 7-8 lbs of boost. thanks.
Mustangs_Suck
THIS IS GOOD FOR 350-375HP
rofl
16-bit
Car: 1991 240sx, KA24DE
well.. good luck on the e-bay turbo kit.
if you want to pick up turbo parts or kits for cheap you gotta go to ka-t dot org. and check out the forsale section. i got about half my stuff through there and bought the turbo, clutch, oil lines, fuel pump, and a few other things new.
hannibal
Car: Red Line to Glenmont
maka wrote:just bought a turbo kit!!!.. what next???/
Throw some boost on that *****!
Chezedik
You simply will not hit that power level with that turbo, and should think of at least a T3.
extreme135
Car: 1995 Nissan 240sx KA-T
Odviously hes not going to make that much power, but you will be fine with what you have to run about 10lbs on that t25, probably make about 225-240whp on 10lbs with a good tune, I would take it somewhere once you get everything together and get it dyno tuned.
