The tow hook is an accessory, they don't come with the car. The part number is 51112-1KA0A, but only IF your car has a receiver for it. Not all do, pop the cover and make sure there's a hole behind it.
Probably the straps for the relocatable deck shelves. Many people don't like or need them, they just remove them and toss them into the spare well.
I'm pretty sure it will do that even if the source is removed, most of the Nissan AV's buffer songs into memory while playing them. I also doubt the "random" function is truly random, that depends how the AV is generating the random seed number. It may not be based on a true random factor like time of day. Lazy programming, but there's a lot of that around these days.
3 people ive messaged on eBay are telling me that 51112-1KA0A will not fit a 2020 Rogue. And some on eBay don't use actual photos or use stolen photos. Why the heck didnt mine come with one?VStar650CL wrote: ↑Tue Aug 22, 2023 6:24 amYou can get them on eBay for as low as about $30, just put the p/n in the search bar. There's also a -1KA0B version that's identical but a different supplier, try both numbers.
So the 2020 is a gen 2? Im very new to Nissan and I'm not a car guyVStar650CL wrote: ↑Tue Aug 22, 2023 11:03 amPS - AllThingsNissan and Z1 both show the -1KA0A fitting the gen2's, so maybe Nissan just screwed up and omitted it from the parts dbase. That wouldn't be the first time.
One thing you might try is to delete the MP3's off the flash drive and then put them back on the flash drive, in whatever order you like. I know some factory radios are real funny about playback order, whether it is in random or alphabetical order. My wife's Rogue is like that, it will only play the flash drive in the order the songs were written to it, so if I add a new album it is always down at the bottom of the list on the display, regardless of the title of the album. We both like for the album list to be in alphabetical order, it makes it easier to use while driving. The only solution I have found for an incorrect order of MP3 albums on her flash drive is to erase and re-write the full MP3 album list back to the flash drive in the new alphabetical order. The radio then will list the files in alphabetical order and random play also works like it should. This might not solve the random play problem in your car but it could be a simple solution, and might be worth a shot.
It wouldnt bother me if it picked up where it left off when i start the car again. Everytime i start the car its like Groundhog Day.Jimmy9190 wrote: ↑Tue Aug 22, 2023 7:47 pmOne thing you might try is to delete the MP3's off the flash drive and then put them back on the flash drive, in whatever order you like. I know some factory radios are real funny about playback order, whether it is in random or alphabetical order. My wife's Rogue is like that, it will only play the flash drive in the order the songs were written to it, so if I add a new album it is always down at the bottom of the list on the display, regardless of the title of the album. We both like for the album list to be in alphabetical order, it makes it easier to use while driving. The only solution I have found for an incorrect order of MP3 albums on her flash drive is to erase and re-write the full MP3 album list back to the flash drive in the new alphabetical order. The radio then will list the files in alphabetical order and random play also works like it should. This might not solve the random play problem in your car but it could be a simple solution, and might be worth a shot.
Jimmy
My 2022 Tacoma came with one and it's literally the most basic Tacoma that can possibly be purchased. (It's a super basic special order that doesnt' even come with rear seats)
Our 2015 had one in the glove box when we bought it new.
