Just bought a Nismo Short Shifter....
chaddicus
Car: 1990 240sx
NOw all I have to do is install it. How hard is this going to be? Never installed a shorty before so I am looking for allsorts of help to save me money. thanks
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
i installed my b&M short shifter on my own, just hard to get 2 of the bolts that are on the transmission. behind the circle hole in the body above the transmission...
ok
Max
Axel Grungy
Car: 2001 G20 5spd
its easy, six bolts IIRC hold the shifter plate onto the transmission, that whole unit pops out, slide in the new one, replace the bolts. make sure to use liquid gasket on the new one. you will most likely have to get under the car to get the two PITA bolts, its what i had to do. assuming this is the same thing as a b&m basically.
240marcuSX
Car: E34 525i
E46 M3
Ive heard that the nismo short shifter feels almost like stock. let us know what you think. but yeah, its an easy install.
Fenvy
Car: 2005 350Z Base 6MT
read my sig for instruction as to transmission fluid exchange, it will have pic/info on how to remove the shifter in the process
barrigas14
the Nismo shifter is a solid shifter. maybe at the most 10% decrease in shifting. it is suppose to be just solid.
chaddicus
Car: 1990 240sx
Solid as in good right?
ILikeMy240sx
Car: SR Power
He means solid as in one piece design where as the stock shifter is two pieces with rubber in the middle to absorb vibration and shock
chaddicus
Car: 1990 240sx
here's a picture of all the parts that came with this short shifter. Anyone know where all this stuff goes and how?
Dookie
Car: 1993 240sx Coupe
thats not a nismo shifter, that looks like a knockoff of a megan racing SS. the nismo shifter doesnt come with a base plate either, its just the stick. Heavy Throttle used to sell them, but I cant find a pic of it to show you.
chaddicus
Car: 1990 240sx
In any event, does anyone know where what goes when installing this Short Shifter?
sensibleS13driver
lol if it was real Nismo do you think they'd put an Accord with altezza lights in their ad?
Modified by sensibleS13driver at 1:49 PM 3/26/2005
hondahunter180
Car: 2003 audi a4 - 1969 bmw 2002 - 1990 s13 (sold)
this is the nismo short shifterhttp://www.store.yahoo.com/pha....html
Fenvy
this is like the nismo steering wheel thread... ha!
chaddicus
Car: 1990 240sx
Ok where are these 2 bolts that are under the car? I can see the four that you unscrew from inside the car while I'm under it but where are these other 2 screws?
Cabezcoco
Car: cars, planes
and i love how is says the 240sx was in production to 2003! And you think nismo would know of all people.
koukiKA240
Car: 1991 240sx KA-T
be carefull on ebay. I saw ur other thread. You need to spend more time on NICO and less time on ebay untill you know a little bit more about the 240sx and how ebay sellers like to dupe people that dont know any better.~Sam
Neejay
Loveless wrote:this is like the nismo steering wheel thread... ha!
/thread jack
loveless, you're NEVER on AIM anymore!! Did you change your SN?
/end thread jack (sorry)
Fenvy
nah I am on but I am Über busy lately so I haven't got the chance to stay on for too long.
Henry G
koukiKA240 wrote:be carefull on ebay. I saw ur other thread. You need to spend more time on NICO and less time on ebay untill you know a little bit more about the 240sx and how ebay sellers like to dupe people that dont know any better.~Sam
Nismo_Freak
Car: 89 Nissan 240SX
That short shifter is a copy of the C's shifter that is in my 240. I love it, and I'd imagine that one is perfectly fine as well.
chaddicus
Car: 1990 240sx
do you still have your install instructions? as far as I can tell, the little plastic round ring goes on top of the ball at the bottom of the shifter and then the metal ring goes on top of that followed by the based plate? Is this correct? if so or not what stock parts do I need to use off the old shifter? if you have a copy of your install instructions I'd be most greatful for a copy. thanks
chaddicus
Car: 1990 240sx
SUCCESS! Shifter installed, thanks for all your help. Now I must move onto the steering wheel.
Nismo_Freak
chaddicus wrote:do you still have your install instructions? as far as I can tell, the little plastic round ring goes on top of the ball at the bottom of the shifter and then the metal ring goes on top of that followed by the based plate? Is this correct? if so or not what stock parts do I need to use off the old shifter? if you have a copy of your install instructions I'd be most greatful for a copy. thanks
It's straightforward once you look at it.
H2Dro420fla
Car: 1997 240sx
I am really interested about how you installed your short shifter chaddicus. I am at a jam. I placed the plastic tipped end in the transmission thing with all the oil in there. But once I tighten down the 6 screws the shifter will not move. It is locked in place until I losen the screws but it still doesn't go in gear. I was wondering if there is some special way of putting the new shifter in the transmission thingy. (Not much of a mechanic)
Fenvy
http://www.heatsinkninja.com/s...9.jpg
refer to my pic.... there are 2 snap rings, remove both and the circle thingy will seat all the way in
BuLLeTdrift
Car: 91 240sx fast baq
do you guys know that part # on the nismo solid shifter?
