Mainly just a daily but I hardly won't be putting to much miles and I needed a truck so I can track my carMinisterofDOOM wrote:Not terribly fond of the 5 cylinder in the Colorado. The 4.2 liter 6 it's derived from is excellent, but the 5 has balance/refinement issues and lacks torque, especially down low.
That wheel and tire package looks pretty good.
What are you planning to use it for? Offroading, towing, haulin' stuff? Or just DD with a bed?
Nice looking truck and I see no issue with it as a daily driver, but I fear you might encounter problems towing a car safely with that truck, as I think the Colorado's towing capacity is only 4000lbs.Ekinchheng wrote:Mainly just a daily but I hardly won't be putting to much miles and I needed a truck so I can track my car
Despite the close hp #'s, the F150 is a full sized pickup designed to tow significantly more than a midsized Colorado. An older F150 4.2 V6 pickup automatic with 3.55 rear, has what, a 5200 lb towing capacity? The Colorado's capacity is just 4000' . So towing a car with a steel trailer should be a non-issue for a V6 F150, but dangerous for a Colorado as you're operating at or above it's designed limits. I recommend driving your car to/from the track instead of towing it with a Colorado.Jesda wrote:You should be fine towing a small car. I do it with a V6 F150 hauling classic cars back and forth across the country. Just keep the speed below 65mph, check your tire inflation, and make sure you have trans cooler and maybe get a trans temp gauge.
I have 205hp. I think you have 220hp. Just be careful and make sure you don't allow the automatic to hunt for gears too frequently.
As someone who tows regularly to/from tracks/sites, towing with a midsize truck is A BAD IDEA. Can you get away with it? Yes. Is it a terrible idea? Absolutely.Jesda wrote:You should be fine towing a small car. I do it with a V6 F150 hauling classic cars back and forth across the country. Just keep the speed below 65mph, check your tire inflation, and make sure you have trans cooler and maybe get a trans temp gauge.
Bubba1 it does make more sense to just drive my car to the track since the track is only about 40 mins away. For insurance, in case my car breaks at the track, I don't want to wait hours for a tow truck when I have a truck and a trailer. For the most part my truck will be a daily just on the weekends.Bubba1 wrote:Despite the close hp #'s, the F150 is a full sized pickup designed to tow significantly more than a midsized Colorado. An older F150 4.2 V6 pickup automatic with 3.55 rear, has what, a 5200 lb towing capacity? The Colorado's capacity is just 4000' . So towing a car with a steel trailer should be a non-issue for a V6 F150, but dangerous for a Colorado as you're operating at or above it's designed limits. I recommend driving your car to/from the track instead of towing it with a Colorado.Jesda wrote:You should be fine towing a small car. I do it with a V6 F150 hauling classic cars back and forth across the country. Just keep the speed below 65mph, check your tire inflation, and make sure you have trans cooler and maybe get a trans temp gauge.
The general rule of thumb is that if you are towing a load of over 2,000 lbs. on a regular basis, you need to invest in trailer brakes and a brake controller. This will allow you to stop the load on something approaching a normal distance as well as reducing the load on your front brakes. Don't hold me too it, but I read somewhere that on pickup trucks because of the way they are loaded 70% of your braking power comes from the front and 30% from the rear. Don't skimp on this guys.....the one time you wish you hadn't could possibly be your last.
I understand. I have a tow vehicle too as cheap insurance (mine is fullsized). I agree both the convenience and peace-of-mind-if something-breaks benefits are huge. Be prepared, when you have a tow setup, you will become very popular in the paddock when someone else breaks down, and they look to find a way to get their car home.Ekinchheng wrote:[
Um, you're the American here... I'm from Italy, and I'm telling you that towing with a mid-size truck is very unwise.Jesda wrote:This is something Americans always go bonkers on. In other countries, compact and midsize pickups (and sometimes small hatchbacks!) are used for towing trailers, campers, and small cars on a routine basis. No pretzeling, no mass casualties.flohtingPoint wrote: As someone who tows regularly to/from tracks/sites, towing with a midsize truck is A BAD IDEA. Can you get away with it? Yes. Is it a terrible idea? Absolutely.
Assuming you're towing a small lightweight car (to/from racing events) and you stay below GM's specified limits, you'll be just fine.
Quality advice:
http://www.355nation.net/forum/how-chas ... orado.html
