sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Sat Sep 10, 2005 3:54 am
The wiring is very very simple, there are only 3 wires besides ground that you need to hook up. The green/black wire on the coil gets cut. From the BTM: Orange goes to the green/black on the plug on the coil. White goes to green/black on the harness. Red splices into the red/black wire on the harness.
Black goes to ground.
The BTM has performed similarly on others SOHC KAs, where it would retard timing immediatly. It's not me, lol. There is something about SOHC ignition (some transistors in the coil and etc etc etc) that make it a little odd to hook up piggybacks to. Maybe it's certain years which used different brand components (Mitsubishi, etc).
sil80
