Just bought a fairlady! 240z
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
Rickjames1964
Car: 89 sil forty
Well oki switched cars this timei sold my 240and bought a classic 240z 1972it only has 80k miles on itand im really new to these carsobviouslyso i would like to see if any of ufellow Z ownerscould maybe give me some specs abouta 240zmaybe problems that u have with thatthat are freqwent on oneor just some basic tuning and maintaining tipsthanks alot guys!
Awesome!
I'm sure we'll have some old-school Z guys chime in soon - Congratulations on the purchase and welcome to NICO!!!
Rickjames1964
Car: 89 sil forty
yeh!i hope so anywayslolwell i hope u guys can help!thanks
jockstrapjc
lets see some pics holmes!!!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
congrats on the Z, the 240's weighed a bit under 2400lbs and rated at 150 gross crank hp, most of us opt for a 2.8, the 72 carbs are less than favorable, most people use the early round top scarbs or the tripple side drafts, or fuel injection or even complete turbo injected 280zxt motors, just depends on how fast you want to go and what kind of budget and what donors are available to you
Rickjames1964
Car: 89 sil forty
bump!come on guysi know u guy have emgive me info!thanks!
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
Nice score man! Congrats! i have big plans for a 240Z once i get one....sooner or later. I'd Check out http://www.Zcar.com or http://www.Zdriver.com for more info.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Congrats on the purchase!
Specifications Engine: 2.4 L (2393 cc/146 in³) I6, cast-iron block, alloy head, seven-bearing crankshaft, single overhead cam, 9.0:1 compression Bore: 83.0 mm (3.3 in) Stroke: 73.7 mm (2.9 in) Fuel system: Mechanical fuel pump, twin Hitachi HJG 46W 1.75 in (44.4 mm) SU-type carburetors Power: 151 hp (113 kW) at 5600 rpm (SAE gross) Torque: 146 ft·lbf (198 N·m) at 4400 rpm (SAE gross) Transmisson: Four-speed manual or three-speed automatic (after September 1970) Brakes: Front: 10.7 in (271.8 mm) discs Rear: 9.0 in (228.6 mm) by 1.6 in (40.6 mm) drums Suspension: Front: Independent with MacPherson struts, lower links, coil springs, telescopic dampers, anti-roll bar Rear: Independent with MacPherson struts, lower wishbones, coil springs, telescopic dampers Steering: Rack and pinion, 2.7 turns lock to lock Wheels: 4.5J-14 steel wheels with 175 SR 14 tires Wheelbase: 90.7 in (2304 mm) Length: 162.8 in (4135 mm) Width: 64.1 in (1628 mm) Dry weight: 2355 lb (1068 kg) Top speed: 125 mph (200 km/h) 0-60 mph (97 km/h): 8.0 s Typical fuel consumption: 21 mpg (11.2 L/100 km)
General Info The S30 Nissan/Datsun 240Z (known in Japan as the Fairlady Z and later in other markets as the 260Z and 280Z) are sports cars produced by Nissan Motors, Ltd. of Japan in the 1970s. HLS30 was the designation of the left-hand drive model and HS30 for the right-hand drive model. The 240Z was introduced in 1969 with a 2.4 liter straight-6 engine, rear wheel drive, and a stylish coupe body. The engine, based on the Datsun 510's 4-cylinder produced 150 hp (112 kW) and came with a 5-speed manual transmission (USA model received a 4 speed manual). A 4 wheel independent suspension consisted of MacPherson struts in front (borrowed from the Nissan 1800) and Chapman struts in back. Front disc brakes & rear drums were standard.
Production began in 1969, the 1970 240Z was introduced to the American market by Yutaka Katayama, president of Nissan Motors USA operations, widely known as 'Mr. K'. The early 1970 model 240Z had a chrome "240" badge on the B-pillar quarter panel. Two vents were included in the rear hatch below the glass molding. In mid-1971 the B-pillar side badges were restyled with the letter Z in white, and the vents were eliminated from the hatch. Design changes for the US model occurred throughout production and are described Design and Manufacturing Changes to the U.S. Spec
The 240Z and 260Z used twin one-barrel carburetors. Fuel injection (L-Jetronic electronic fuel injection, designed by Bosch) was added for the 280Z in 1975. This was primarily in order to cope with the difficulty faced in getting enough power using carburetors while still meeting US emissions regulations.
Due to its relatively low price compared to other foreign sports cars of the time (Jaguar and Porsche), it became hugely popular in the U.S. and was the first major success for the Nissan Motor Corporation, which at the time sold cars in North America under the name Datsun. The 240Z also broadened the image of Japanese car-makers beyond their econobox success. The Z was very successful in racing in the 1970's and is credited as a catalyst for the current import performance parts industry.
240Z_Master
Car: 1971 Datsun 240Z
You should drop a serious motor in there like mine!
Rickjames1964
Car: 89 sil forty
whoa ****!an rb?!man u gotta show me some pictures
Return to “Datsun Z Forum”
